LT1 fuel tank swap to third gen
Car: 1987 IROC-Z
Engine: 5.7L
I have a 1987 iroc-z, 350. I have three questions;
#1 Is the Lt1 gas tank metal?
#2 is it a direct swap for our vehicles?
#3 does it have the fuel pump baffle?
I've searched a few posts on here for a definitive answer but have been unable to locate it. Thanks in advance.
Car: 87 Camaro LT
Engine: 383 Twin Turbo - In progress
Axle/Gears: 3.43
Re: LT1 fuel tank swap to third gen
Yes the LT1 gas tanks are metal. The plastic tanks didn't show up until the LS1 years. As for your other questions, I cannot answer. The LT1 tank should fit no issues but more than likely it'll require modifications to the fuel lines
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The filler neck should be longer, and may stick out the side of the car, and since it is metal, you can't just trim a piece of hose the proper length.
Look for a 91-92 tank if you want the baffles
