Tube K Member Fabrication?? - Third Generation F-Body Message Boards
Go Back  Third Generation F-Body Message Boards > Tech Boards > Fabrication
Reload this Page >
Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Old 05-24-2018, 06:27 PM
Car: 1992 Camaro RS
Engine: TPI 350 Small block
Axle/Gears: 2.73 I think
Has anybody fabbed their own tubing K member to replace the stock one? Also I'm looking for a sub frame connector design that allows clearance for old school corvette side exhaust.
Peregoyethan is offline
Old 05-28-2018, 07:58 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Tube K Member Fabrication??
Unless you're very good at steering and suspension geometry, you will be much better off buying an aftermarket replacement. There are many to choose from.
Side exhaust on the corvettes was only because there wasn't enough room under the car to run a large dual exhaust system.
AlkyIROC is offline
Old 05-29-2018, 05:47 AM
83 Crossfire TA's Avatar
Car: 87TA 87Form 71Mach1 12SHO 04Cummins
I'm not sure why you'd have to have much suspension/steering geometry knowledge unless for some reason you wanted to move the LCA pivot points. The rest of the suspension does not attach to it, and WRT to making one you'd mostly just need to set up a fixture to locate the body mount points, LCA pivots and spring pockets and connect the dots.
A more important consideration is having a good concept of mechanical properties and the strength you need in your structure.
83 Crossfire TA is offline
Old 05-29-2018, 06:12 AM
soloc4's Avatar
Car: 84 Z28, 92 Corvette suspension, ABS
Engine: 408 ci LS2, CNC'd LS3 heads
Transmission: T56 w/ RTX clutch, B&M shifter
Axle/Gears: 3.73 w/Tru Trac diff.
Yes you can fabricate your own, I did mine because of the Corvette suspension I installed. Alky and Crossfire both make good points, there are a lot of companies that sell these, and it is as easy as jigging the LCA's and mount points and connect them together. Welding skills are the deciding factor, this is not for a first time project. As far as the sub frame connectors, Global West makes a set that are tubular and mount along the pinch weld (actually weld them to the pinch weld), which would give you a convenient place to mount the side pipes to with some tabs.
soloc4 is offline
Old 05-29-2018, 12:52 PM
Car: 1992 Camaro RS
Thanks for the help guys. I"ll definitely be looking into those subframe connectors you mentioned soloc4. I've definitely got the necessary skills and i should be able to use inventor to run a stress analysis of my design.
Old 05-30-2018, 06:18 AM
being able to run a piece of software to run a stress analysis is quite different than having some talent for designing and building this kind of thing. AAMOF, I feel that you kind of have it backwards, you come up with what should hold together based on your materials and skills and then as a last step test it in the software, maybe I'm old school but I don't feel like software can replace common sense and experience, it can just add a quick check to make sure that you didn't miss something.
Honestly, thinking about this I don't see the gain. I have the skill to build something like this but didn't bother since by the time you build a fixture significantly beefy to build this on you've wasted more money in materials and time than just buying a good one. The only way it makes sense is if you're going into production, and honestly, if you're asking this question you shouldn't be considering going into production, you're going to kill someone.
Old 05-30-2018, 10:52 AM
Car: 1992 Camaro RS
Nothing can replace common sense and experience, but combine common sense and experience with the capability to find the exact point at which a design will fail without having to doing a destructive test and you can fine tune your design. After taking into consideration the point you brought up about costs I'm most likely going to shelve this project because lowering the cost was the whole point of it.
Old 05-31-2018, 09:29 AM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, others
Engine: 412" sbc, LT1, etc
Transmission: TH350, 4L60E
Axle/Gears: 10 bolt, 3.42, Dana36 3.07
Eh.. The spohn ones are way off. Perhaps some suspension/steering goometry knowledge would have helped him!
-- Joe
anesthes is offline
Old 06-01-2018, 06:01 AM
-- Joe
siphon stuff is surprisingly off and I've never thought it was well designed, PA is another one. I've seen their K-members fall apart (supposedly their newer stuff is better) but there are good choices out there. UMI seems to have their **** together, I'm sure there are others.
iroc192
11-08-2007 10:22 PM
8T8IROC
Southern California Area
10-20-2007 04:06 PM
turbosonoma
05-07-2005 09:44 PM
Formula305FI
01-24-2003 11:11 PM
Max
02-24-2001 12:39 PM
Quick Reply: Tube K Member Fabrication??
Advertising
Featured Sponsors
Vendor Directory
Contact Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
