1989 Pontiac Formula V8 5 speed Autocross
1989 Firebird Formula. I traded for this car at the Grand Run a few weeks ago. Very well built and set up for Autocrossing or Road Racing. Original paint in good shape, very solid car with no rust. Built in Florida. I have receits and manuals for most of the parts used on this car. The receits alone add up to over $9000.
355 Roller motor with 6000 miles on build
Ported stock heads with guide plates
Comp Cam
Eldelbrock 110gph fuel pump
Demon 650 carb
Eldelbrock air gap intake
Moroso high temp plug wires
Aluminum Radiator with electric fan and painless harness
Smog pump and A/C delete
G-Force built T-5 tranny
Straight cut gears
27spl. 2 piece main shaft
O.D. gear set
Pro 5.0 shifter with SLP shift ****
Hays billet flywheel
Centerforce 2 10.4" clutch
Aluminum driveshaft
SLP Headers and 3" Y-pipe
Dr. Gas 3" mid pipe
Spin Tech Super Pro Street 3" muffler
3.42 gears
Moser 26 spline axles
Auburn Pro Locker
DTS shims / Solid Spacer / Diff cover
4Wheel Baer C4 / 1LE disc brake conversion
Earl's stainless brake hoses
WS6 suspension
Subframe connectors
Torque arm
Spohn Tubular steering brace
Spohn Panhard bar
Spohn Caster / Camber plates
Spohn Strut retainers
Spohn Transmission mount and sway bar bushings
Eldelbrock strut tower brace
17x9 and 17x11 Corvette ZR1 wheels
275 and 285 Khumo Ecsta Tires
4th Gen leather seats front and back
New carpet
New weather stripping
New headlight motors
New automatic trunk latch motor
I'm a Jeep guys, so will trade for a Jeep or may consider other Muscle Cars.
http://www.collectorcarnation.com/Po...html?aid=32799
Comp Cam
Demon 650 carb
Straight cut gears
O.D. gear set
Aluminum driveshaft
Dr. Gas 3" mid pipe
3.42 gears
Auburn Pro Locker
WS6 suspension
Subframe connectors
Torque arm
Spohn Panhard bar
New carpet
