Maryland 1990 Trans Am drag/bracket car with trailer - Third Generation F-Body Message Boards
Firebirds for Sale Post your Firebird for Sale.
Thread Tools Search this Thread
Old 08-20-2015, 12:21 PM   #1
1990 Firebird bracket car with open trailer for sale. Car runs regular 10.8x's @ 120+ on pump gas and has been some 10.60's in good air in the fall. 60's are 1.44-1.46. Just don't have the time or interest to race much anymore so I'd like to sell my car and trailer. Located in Maryland just south of Baltimore. Clean title in hand for car and trailer. The car is very streetable. Still has radio, power windows and locks, etc.
-Body: 1990 Firebird, T-Tops, no rust, painted 3 years ago, 8pt roll bar, subframe connectors, full interior, Harwood 3" cowl hood.
-Engine: SBC 385ci, Eagle crank, 5.7" h-beam rods, Mahle pistons, Total Seal rings, King XP bearings throughout, hyd roller, Comp 236/242*, double roller timing set with torrington bearing, AFR 195 heads fully ported, 11:1 compression, Milodon oil pan, Ported RPM Air Gap intake manifold, Custom built Holley carb w/QFT baseplate (flows actual 780cfm), 1.6 roller rockers, stud girdle, Hedman longtube headers, true dual exhaust with Magnaflow stainless mufflers, Powermaster mini starter and high output alternator,Powermaster mini starter, Powermaster high output alternator, Proform electric water pump.
- Transmission: TH400, Hughes 3500 converter, B&M Magnum Pro Grip shifter, large cooler plumbed with -6an lines.
- Rear: Strange 12 bolt, Eaton posi, 4.11 gears, also spare set of 3.73 gears included, custom steel driveshaft.
- Suspension: Spohn torque arm, Lakewood 90/10's front with trick springs, 50/50 in the rear with stock V6 springs, Spohn lower control arms with welded relocation brackets, subframe connectors.
- Fuel sys: Mallory comp 140 fuel pump, Aeromotive regulator, custom Holley double pumper carb with QFT baseplate, 4 corner idle, flows 780cfm, plumbed with all -AN lines.
- Misc: Brand new custom Cap5 Champion Billet wheels, 15x10 and 15x3.5" with brand new MT Pro Bracket radial tires on the rear and MT Sportsman front tires, ARC touch switch panel and relay board, deep cycle AGM battery relocated to the rear with cut-off switch and sealed box and properly wired.
Trailer also included, built in storage area with Craftsman tool box, shelves, 12V battery and winch. Trailer has good trailer tires (not car or truck tires), electric brakes, LED lights, 48" beavertail with sliding ramps.
$8500 for all.
1990 Trans Am drag/bracket car with trailer-img_4300.jpg   1990 Trans Am drag/bracket car with trailer-387130_4052103854486_1886926440_n.jpeg   1990 Trans Am drag/bracket car with trailer-551681_3650530695408_1440495899_n.jpg
Dialed_In is offline   Reply With Quote
Old 08-20-2015, 12:27 PM   #2
TTOP350's Avatar
Re: 1990 Trans Am drag/bracket car with trailer
That looks like a smoking deal. If only you were closer.
Free bump
TTOP350 is offline   Reply With Quote
Old 08-20-2015, 01:45 PM   #3
Haha thanks. I'd meet you halfway
Thread Thread Starter Forum Replies Last Post
[CA] GM original OEM Driver Side Door Glass 1992 Trans Am Exterior Parts for Sale 5 04-04-2016 12:50 PM
Whats she worth? Exxon Limited Camaros Wanted 22 12-21-2015 10:36 PM
'90 Firebird T/A no Speedo after replacing ECM marcusaw DFI and ECM 4 08-10-2015 08:13 AM
Dash Conundrums Jorlain Interior 7 08-08-2015 11:46 AM
[OK] 1982 TRANS AM ROLLING CHASSSIS WITH CROSSFIRE AND TRANS 3rdgenparts Firebirds for Sale 0 08-06-2015 09:03 AM
Go Back   Third Generation F-Body Message Boards > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
Vendor Directory
1982 Camaro '82 || 1983 Camaro '83 || 1984 Camaro '84 || 1985 Camaro '85 || 1986 Camaro '86 || 1987 Camaro '87 || 1988 Camaro '88 || 1989 Camaro '89 || 1990 Camaro '90 || 1991 Camaro '91 || 1992 Camaro '92
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
