1988 Trans Am GTA 5-speed 305 ttop IN
Car: 1988 Trans Am GTA
Transmission: 5-Speed
Axle/Gears: 3:45
It has the 305 TPI with and the T-5 manual tranny, 3:45 gears in the differential. I have two 12" subs in the back, I plan to remove them and the amp but I will leave the custom built box, all wiring, head unit, as well as the replacement deck speakers I put in. Custom floor mats and shift ****. I have a lot of extra parts I can give with the car including TWO EXTRA SETS OF TTOPS (one glass, one plastic) an entire intake system, and other misc parts. Runs and drives, although it's running extra rich right now, I believe the timing is off a bit and it burns a bit of oil. The car has about 118,xxx miles on it.
The body:
Paint isn't the best, and there's a small dent with primer over it on the front fender, along with a scratch on the same fender. The driver side rocker panel is cracked but I have a black replacement one I plan on selling with the car. There is a spot with paint coming off on the rear bumper as well. There's a couple of very small rust spots appearing where paint is chipping, but nothing that will stay after being repainted. Also I have installed the high rise Iroc-Z spoiler.
Mods/work done (that I can recall):
Flowmaster exhaust (no cats but still has a muffler)
Smog pump delete
NRG steering wheel with quick release (still have stock wheel if you want it)
Iroc-z spoiler
A/C has been recharged with R12 (impressive right?)
VATS bypassed
Turn signal switch replaced
New power steering gearbox
New starter
New ECU
Newer alternator
Newer brakes
Oil change less than 1k miles ago (Royal purple and K&N filter every time, always before 5k miles)
Random things to keep it running.
Bloomington, IN
asking $5,000 obo
will upload interior pics tomorrow
third gen expo 2015
passenger fender dent
passenger fender scratch
driver side rocker panel crack
The body:
Smog pump delete
Iroc-z spoiler
VATS bypassed
New starter
New ECU
Newer alternator
Newer brakes
Bloomington, IN
asking $5,000 obo
third gen expo 2015
Re: 1988 Trans Am GTA 5-speed 305 ttop IN
In addition to the interior photos, some engine and (if possible) underside photos would be helpful too. Also you might want to list the miles.
Looks like a decent car other than the 1991-92 Z28 spoiler (never been a fan of those personally). Just doesn't look right on a T/A, but I understand the problems with the original aero spoilers.
Axle/Gears: 3:45
