[NY] 1987 firebird 305 t-top
Car: 87 firebird
Engine: 5.slow 305
Axle/Gears: The one that turns and does stuff
hello, i have a 1987 firebird t top with a carbed 305 and automatic 700r4 trans. i bought the car in oct 2018. i bought it from a guy that started to fix it after hitting a deer.
he replaced the front bumper front fenders and hood. power windows power steering power brakes no ac. runs and drives NO RUST clean car little surface rust behind
rear wheel size of a quarter
New
front calipers, pads, rotors, wheel bearings, seals , front brake hoses, radiator, rear drums, wheel cylinder, hei distributor, plugs, wires. im sure theres a few im forgetting
all locks match key including t tops all gauges work, clean title in my name
The NOT GOOD
needs a little tinkering, i painted the car not very good job but better than it was, interior is worn but functional
tv cable needs adjusted but tranny shifts strong
i converted the car from a computer controlled quadrajet to and edlebrock 1405 4bbl carb
i have the old quadrajet it need full rebuild if you want it.
headlight motors are 3 wire cars harness is a 2 wire i tried to get them to work but both wires for each headlight have constant power and wont move light up or down so i beleive module is bad the headlight motors work if you put power to them drivers side head light inside mounting tab is broken so dont sit right.
weld splatter on winshield and passanger window was like that when i bought it
the reason im selling is because my father recently passed away and i now have his 1978 dodge magnum which was his baby so i want to fix his and drive in his memory
i cant have 2 cars so the firebird is going. i never had a chance to put it on the road but i got the title in my name. with some tlc and love itll be a good car.
im posting this for 2000 or best offer located in oswego ny.
im sure theres more im missing call text or email. if you have any questions or want a specific pic .
Closurdo91@gmail.com
3158062163
my name is chris
New
The NOT GOOD
3158062163
my name is chris
thirdgencrazy1
10-16-2011 09:35 PM
