Firebirds Wanted Looking to buy a specific Firebird? Post your Want Ad here.
[OH] WTB 1991-1992 firebird base or Formula
Old 11-10-2017, 04:09 PM
Black00SS's Avatar
Car: 1992 Trans Am
Looking for a rust free 1991 or 1992 firebird.
Hardtop, 5 speed. Formula, or base firebird (without ground effects) are the only criteria.
Lmk what you got!
Old 11-11-2017, 10:48 AM
Black00SS's Avatar
Car: 1992 Trans Am
Re: WTB 1991-1992 firebird base or Formula
Just thought I would add a little more.
This would be for a long term project. As long as its a 91-92 firebird base (no ground effects) or Formula, hardtop, 5 speed I am interested.
Any engine (or none possibly), any options, etc.
Price range would be anywhere from 500-3500 depending on what you have.
In Ohio here, but willing to travel for the right car/deal (the better the car/deal, the farther I am willing to travel).
Thanks, reply here or PM is good too.
Old 12-27-2017, 10:54 PM
syoung_2000's Avatar
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
I have a 1992 formula 305tpi, disc rear end with 3.73 richmonds. 5spd.
Brand new magnaflow catback, Dyno Don's headers with ceramic coating on inside too (per request), Founder's Performance LCA & Panhard bar, aluminum driveshaft, all new hoses, brake lines, brake hardware, radiator, heater core, and most every other replaceable part, etc. I bought a ton of parts, and never put them on, or they were put on, but never got the car back together since then. Was originally a 2.73 drum, automatic.
Everything is in place for conversion. (Pedals installed, Dakota Digital - to correct the speedometer for new gearing, 5 speed shift boot, proportioning valve installed for disc brakes, etc...)
Rear end, WC T5, and aluminum driveshaft are from 91 camaro.
I bought the car, drove it for one day, parked it and tore it apart with intentions to upgrade it and replace every part, whether it needed it or not, so when I was done, I'd have something "100% new" I could drive across country with no worries.
Mid-way through this project, I had shoulder surgery, then kitchen remodel, house projects, etc...
It's been setting in my garage on concrete floor for 4-5 years that I've owned it.
102,000 miles. I have a clear title.
NO RUST!
I'm located in Washington Court House, Ohio
