If you have a Players Challenge Car, please post here. (RPO- A4U, 1LE or R7U)
#701
Re: If you have a Players Challenge Car, please post here. (RPO- A4U, 1LE or R7U)
Since buying the Players TransAm I’ve spent countless hours and dollars getting it up back running. It hasn’t turned a wheel under its own power in well over a decade. It was well worth the effort. I ended up swapping the engine from an 88 Iroc (LB9) and still have the numbers matching block. Runs awesome!
I am however listing the car for sale to a good home. You can find it in the classifieds section on this site.
#702
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
TTOP350 (12-10-2019)
#703
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 700R4 w ProBuilt
Axle/Gears: 9 bolt 4.11
Saw this on Kijiji...https://www.kijiji.ca/v-classic-cars...iac/1446563103
#704
1 Post
Car: 1988 A4U (#99 SONY/Protec)
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
Anyone familiar with Players engine block codes? I picked up an ‘89 yesterday but was told the engine was replaced. The paint markings are present and the block has no VIN. Code is V0708PW1 if I’m reading it right (it’s filthy and I haven’t pressure washed it yet). Is there a chance the PW stands for warranty? Thanks
#705
My 1989 R7U had the original engine. V0111ATB
V- Flint Engine Plant
01 Jan
11- 11th day
ATB - 1989 305 LB9
Not sure about PW1. I can’t find that suffix code anywhere.
#706
1 Post
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
#707
Engine: TPI(s)
Use a mirror to check back driver's side of block. See what casting number is there. Should be a 5.0L indication as well. No VIN usually means service replacement block. So the Engine code may not match any listing since it didn't come in a particular car/truck.
Mark.
Mark.
#708
Howdy,
If you have what you think or know to be a genuine players challenge car, please post your info here.
I am collecting as much information about the series and the cars as I can. I'll be adding it to my web page as I collect info for all to enjoy.
Hot items: How many players cars were produced each year?
Mark
History of the Players LTD./GM Motorsport Series
1988 Trans Am
Mark
1988 Trans Am
#709
1 Post
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
Thanks Mark. At least the block is consistent. The rear has no VIN either. Although the suffix doesn’t show up anywhere anymore the guys at GM agreed with your suggestion of a replacement! Maybe someday it’ll show up.
#710
Engine: TPI(s)
I have an 88 gta, VIN 1G2FW2181JL231308, I'm unable to read stickers on dr. door. Any other way to verify a rpo A4U ?
#711
Engine: TPI(s)
Keep searching ... it will show up.
#712
So please tell us a little bit about your new purchase.
#713
1 Post
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
The car was found in a field nearby - less than 1/2 hour actually. I’ve probably driven by it thousands of times easily, few weeks back I just happened to spot it, sounds like it was pulled out to be sold. The owner told me his dad had 10-15 thirdgens at one time and over 100 vehicles and crushed them all years ago. I was interested as a parts car until I found out what it was. Car is in rough shape but complete minus cage. He said it was the fastest iroc around (after I figured out the car and found the race chip I know why lol).
Initially I was going to rebuild it as it’s a better start than my 88 was, but now I’ve already found another so I’m trying to sell. If it doesn’t sell I may start on it once I’m finished mine. Ideally Id like to find someone who is interested in restoring it, had lots of interest for parts but seems wrong. Once the snows gone I’ll fix the fuel pump and rip it!
At first I thought it might be Ernie Romanov (who never raced after provisionals). However now that I’ve talked to a couple of the racers from Stony Plain it may be one of the Dowlers cars. I’ve got lots of interest in tracking down its origin so I hope to tie it up soon and get some pictures,
#714
Engine: TPI(s)
And a new car found in the dust of storage ... a 1991 Player Challenge Trans Am ... 1 of 9 built in 1990. Raced two seasons in the series. Then some street miles, and back on the track in full race trim. The plan is either A. put back to street spec as it was racing in 1991 or B. Keep it as it is for vintage racing (but not sure how much you can modify for a vintage race).
#715
Did the car stay local or go south?
#716
Craigslist find of the day. Not sure of the years of jackets
DynoDave43 (12-01-2019)
#718
1 Post
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
Great pick up. Top left is ‘88 (I have only ever found one - good match for your Morris car). Then ‘89-90 is rainbow, red and white is ‘86. The GM Motorsports I was told was for GM only and not available to the teams. Only missing a couple to complete the set!
#720
Car: 1987 Trans Am
Anybody have a set of used 1LE rotors they would sell. Don't care if they are worn, as I just want to make hubs out of them. Thanks, Ryan
#721
Looks pretty modified. Anybody know anything about this car
https://www.kijiji.ca/v-classic-cars...rce=ios_social
#722
Not your usual listing. 14 players cars in one spot.
http://www.autotrader.ca/go/5-48515817
If this guy isn’t a member he should be.
*i needed a refresher:
http://www.playerschallengeseries.ca/Production_nos.htm
TTOP350 (11-04-2020)
#723
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
That is quite impressive!
#724
1 Post
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
Anyone on here running stock GM brake hoses on front for an A4U? Curious if you're using the shock bracket for the hose? Pictures would help! TIA.
#726
Engine: TPI(s)
#728
1 Post
Engine: 5.0 V8 TPI
Axle/Gears: 3.45
So... I put off painting the car for a bit to get a cage installed. I am fortunate enough to have the car's original crew chief close by and willing to help - he had two stipulations 1) He wasn't building a cage in a recently painted car 2) He be allowed to re-create the cage as he originally built it. I obliged! I was without the car for 2 months and between he and his helped they counted over 150 hours... I couldn't be happier. It's an exact copy of the 1988 cage, built on the same bender and using the same mounting locations. At 73 years old he is still very capable of amazing work. I've already started pulling it to paint the car and have the cage coated.His cage was unique as he refused to cut the dash unlike some of the larger team cages = a lot more work to get the bends right...
#729
So this original Davenport cage followed me home today, it’s still unconfirmed but it may be the original cage from my #88 Tony Morris Camaro . It’s all complete. Drivers door bar is missing in photo but I have it. Small win!!
#730
This 1989 eastern players R7u car was stored in a semi trailer just north west of Calgary Alberta in a small town for the last 18 years. Original cage , prom and is probably the heaviest documented cars I’ve seen.
Munyguy (04-27-2021)
#731
Engine: TPI(s)
Great finds! I like the dusty car from a trailer!
#732
Found on for sale on Craigslist list. Active as of today.
1988 IROC Z PLAYERS CHALLENGE A4U 1LE
https://baltimore.craigslist.org/cto...389525174.html
DynoDave43 (10-17-2021)
#734
nice car I’ve seen it in person very clean
#735
Paint complete on the #88 Morris car
#736
1G1FP21F8JL146157
Vehicle: CAMARO 2 DR
Year:1988
Build Date: Unk.
Found 4,705 vehicles matching that year and model in our database.
RPO Description Matches 15P WHEEL COLOR,MEDIUM SLATE GRAY (15P) 1,514
19C TRIM COMBINATION,CLOTH,BLACK (19C) 900
19I INTERIOR TRIM COLOR (19I) 1,482
199 SEAT BELTS COLOR BLACK (19) (199) 1,482
40U EXTERIOR COLOR,PRIMARY,WHITE (40U) 980
6DB Unknown 458
7DB Unknown 458
8NL Unknown 1,819
9NL Unknown 1,819
90A ACCENT STRIPE,TWO-TONE,SILVER/YELLOW (90A) 296
AM9 SEAT,REAR,FOLDING SPLIT BACK FLDG SPLIT BK R/SEAT(AM9) 2,704
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 4,705
A01 WINDOW,TINTED GLASS(ALL WINDOWS) TINTED GLS(A01) 4,290
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 3,325
A4U CANADIAN PLAYER'S CAR (1987 AND 1988 ONLY) 71
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 4,156
B18 ORNAMENTATION,INTERIOR(DELUXE)(USED WITH TROFEO SPORT COUPE WL3) DELUXE INTR(B18) 2,832
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34) 4,680
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35) 4,680
B6Q Unknown 1,165 CD4 WIPER SYSTEM,WINDSHIELD,PULSE PULSE WPR(CD4) 4,156
C41 HEATER,OUTSIDE AIR,WITH FAN AND DEFROSTER HTR(C41) 2,432
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 4,166
C95 LAMP,INTERIOR,ROOF COURTESY AND DUAL READING DM & READING LP(C95) 3,484
D34 MIRROR,INSIDE,SUNSHADE S/S MIR(D34) 2,221
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35) 2,606 D7J Unknown 207
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80) 1,782 D88 STRIPE,SPORT SPORT STRPE(D88) 4,483 E5Z ADAPTER - SPEEDO - DELETE 4,705
E7Z SENSOR - VEH SPD - DELETE 4,705 E9Z KEY - SPEEDO - DELETE 4,705
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2) 2,216
GM3 AXLE,REAR,3.45 RATIO 3.45R(GM3) 207
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 1,847
G92 AXLE,REAR,PERFORMANCE RATIO(MERCHANDISING OPTION) PERFORMANCE R/AXL RATIO(G92) 935 J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65) 790
KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4) 935
K68 GENERATOR,105 AMPERE 105 AMP(K68) 1,847
LB9 ENGINE,5.0L(5.0F),V8 EFI CAR ONLY 5.0F(LB9) 1,264
MK6 TRANSMISSION,MANUAL 5-SPEED(BORG-WARNER) 5-SPD M/TRANS(MK6) 207
MM5 TRANSMISSION,MANUAL 5-SPEED PROVISIONS(MERCHANDISING OPTION) 5-SPD M/TRANS PROVISIONS(MM5) 1,489
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 4,703
NP5 STEERING WHEEL,SPORT,3-SPOKE,LEATHER WRAPPED(USED WITH SE Y92) LEATHER WRAPPED STRG WHL(NP5) 2,221
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33) 4,156
N65 WHEEL AND TIRE,SPACE SAVER SPARE(STEEL) STOWAWAY SPARE(STEEL)(N65) 1,731
N96 WHEEL,16X8,CONVEXED,FOUR RIBBED,HI-TECH TURBO,WITH CENTER CAPS AND CAP WHEEL NUTS(STAMPED PONTIAC)(ALUMINUM)(USED WITH TRANS AM WS4,PERFORMANCE PACKAGE WS6,AERO WW2) AL WHL(N96) 1,847
PB4 LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4) 4,705
QDZ TIRE,ALL P245/50VR16/N BL R/PE ST TL HW4 TIRE(QDZ) 1,847
TR9 LAMP GROUP,COURTESY LP GRP(TR9) 4,156
TT4 HEADLAMPS,TUNGSTEN QUARTZ HALOGEN HALOGEN HDLP(TT4) 4,703
T93 LAMP,TAIL AND STOP(SPECIAL)(DELETES CHROME EDGING)(USED WITH INTERNATIONAL
WJ9,SPORT PACKAGE WM3) SPECIAL TAIL & S/LP(T93) 2,221
T96 LAMP,FRONT FOG(USED WITH GROUND EFFECT PACKAGE B5U,SPORT PACKAGE Z13) FRT FOG LP(T96) 2,221
UA1 BATTERY,HEAVY DUTY HVY DUTY BAT(UA1) 1,679
UM7 RADIO,AM/FM STEREO,ETR,INCLUDES CLOCK STEREO W/CLK(UM7) 597
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 4,705
U25 LAMP,INTERIOR,REAR COMPARTMENT COURTESY RR COMPT CTSY LP(U25) 4,156
U26 LAMP,INTERIOR,ENGINE COMPARTMENT COURTESY E/CMPT CTSY LP(U26) 4,156
U29 LAMP,INTERIOR,INSTRUMENT PANEL,COURTESY I/P CTSY LP(U29) 4,156
U79 SPEAKER SYSTEM,4,DUAL FRONT COAX,DUAL EXTENDED RANGE PACKAGE SHELF 4 SPKR SYS(U79) 4,622
VAN Unknown 4,705
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 4,700
V73 Unknown 4,705
WW1 AERO PACKAGE(WHITE)(USED WITH AERO PACKAGE W62) AERO PKG(WW1) 538
W62 AERO PACKAGE AERO PKG(W62) 4,705
X06 Unknown 2,055 YR1 SEAT,FRONT(CUSTOM) CUSTOM ST(YR1) 2,832 YS1 SEAT,REAR(CUSTOM) CUSTOM RR ST(YS1) 2,832
YT1 BUILD-UP,CUSTOM DOOR AND QUARTER CUSTOM DR & QUARTER(YT1) 2,832
Z28 SPECIAL PERFORMANCE PACKAGE,IROC-Z(MERCHANDISING OPTION) IROC-Z PKG(Z28) 2,221
Z31 IDENTIFICATION - PRICE SHEET ADVANCE 4,684
Z49 MANDATORY CANADIAN BASE EQUIPMENT MODIFICATIONS(CANADIAN) CANADIAN(Z49) 4,704
Was N96 also used on the Camaro? I never noticed this before...
#737
Transmission: World Class T-5
Axle/Gears: BW 3.45
Maybe I can link this thread here for some answers.https://www.thirdgen.org/forums/hist...89-1990-a.html
#738
(cross posting this here)
I am very happy to be able to provide some pictures of some ultra rare GM race only f-body parts. Below are pictures of a racing exhaust system built for the 87-92 Player's Challenge series races in Canada. This exhaust system was available over the parts counter to racing teams and was required to be installed on the race cars.
The system is "bolt on" in the sense it replaces the main crossover (notice the lack of the dual cat N10 setup). The side pipes install in place under the door sill area and exit just infront of the rear wheels.
The chrome extensions are 1970 Chevelle SS parts that have tabs welded on the inside with threaded holes to allow for an aluminum cap to be put on. The design allowed for driving the car to the track with closed exhaust, and then upcap the exhaust for the race.
While the HP gain was minimal, the exhaust was really for the fans. In 1986, they had only a passenger side exit. By 87, then added the driver's side for true exhaust so they could assault the fans on both sides of the track.
This exhaust system is BRAND NEW, NEVER INSTALLED. Still has the tags and part numbers intact. It was an unbelievable find and a part of history. I'll be blueprinting the setup and taking better pictures as time permits.
I could not wait to post up some picts. Early Christmas!
Enjoy.
Mark.
Here are the pipes unassembled. 3 parts made up the package.
Here they are loosely assembled.
Here is a close up of the side pipe. There are some strange bends to get out and under the door.
Enjoy.
Mark.
#739
“RARE” Beechwood color interior
1LE track package dash emblem (aftermarket)
Custom leather interior
Radio delete
#740
It’s a tight fit but the original Davenport cage is back in the #88 car
#741
Engine: TPI(s)
Looks great! Some small differences with the final design cage Davenport used. How is the fit on the main bar floor area?
And once the cage is in, the car feels so solid!
Mark.
Mark.
#742
1 Post
Car: 87 Players Challenge Transam
Engine: 355 TPI
Transmission: 5speed
Axle/Gears: 3:42
I was at Westwood in August '88 and took a bunch of pictures during the Players race. I found these of your car. Hope they help.
MikeJR1991 (01-04-2022)
#743
U[QUOTE=Mark Transam;6452882]I was at Westwood in August '88 and took a bunch of pictures during the Players race. I found these of your car. Hope they help.
[/QUOTE
nice photos Mark. The Esso protect car is owned by Paul from Alberta. The previous post is the #88 Flag car
[/QUOTE
#744
TTOP350 (01-06-2022)
#745
#746
#747
Engine: TPI(s)
Part of the car inspections were to have all the equipment in, as well to adhere to corner weights, ride heights, sway bar size and so forth. In later seasons they allowed teams to remove the hood insulation, as well as not be registered for street duty. Around 1990 or so in order to keep costs down. In 86 teams were encouraged to drive them on the street and to and from the race track ... which also required a $5000 bond to prevent "stunting" on the street.
It was weird to install the rear seat with a rear rollbar. It's snug.
Mark.
Mark.
okfoz (01-13-2022)
#748
One of 53 1987 A4u Players Challenge Series cars. Was sponsored by Datastern and Wolf Chev Olds and raced one season by George Aron out of Calgary Alberta. Should be a fun project
The following 2 users liked this post by 67restoproj:
DynoDave43 (01-18-2022), z28cop (01-16-2022)
#749
Engine: TPI(s)
Mark.
#750
so it looks like I have one of these fancy race-bred Camaro's. Mine is an 87 that I bought minus motor and trans. I had no idea that it was a special car until the owner of BMR let me know that the car was different when their battery relocation kit wouldn't fit. I will post up the pertinent info here soon. I have had the car since 2005 and it has been a project ever since. I am pretty close to having it running and driving. And yes, I have gone the way of road race setup as far as suspension and bracing. No cage yet. But maybe down the road.
