READ ME! Before asking "Is my car rare/Desirable?"
#101
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: READ ME! Before asking "Is my car rare/Desirable?"
I estimate there were probably around 200 or so for 1992, I would think it would be similar for 1991 as I see about the same amount for both years. The option was a late option change for the 1991's so even though there were more 1991's made the availablilty timeframe was smaller.
#102
Car: 1985 IROC-Z28
Engine: 305 HO (L69)
Transmission: Rebuilt T5 (updated T5 parts)
What about the 508 1992 GTA's? (forgive me if I'm wrong)
#104
Car: 1988 IROC Z28
Engine: 305 H.O. LB9
Transmission: T5 5-Speed
Axle/Gears: 3.45
First, I'd like to say great list/great thread, thank you for all the work and research. I have a question about the "1,665 (1985) Trans Am L69 5.0 H.O." entry. Is that number all 5-speed cars, or were automatics available with the L69 also? I am curious because I just bought a 1985 T/A with the L69 305 H.O. , MM5/M39 5-Speed trans, G80 (limited slip), GS4 (3.70 ratio), and J65 (4 wheel disk). Is there any way to tell if the 1,665 all included the same equipment as mine, or does my car break down farther (rarer?) than that. Any help would be great.
#105
In 1983, 1985 & 1986 the "H.O." was only available with the Manual Transmission. 1984 was the only year that the Automatic was available. The reason for this is there was no other top engine in 1984. Where in 83 you had the CFI, and in 1985 & 1986 you had the LB9 (TPI) as the top engine, 1984 only had the L69...
So to answer your question there is no further break down...
John
John
#106
Car: 68 CAMARO, 05 VETTE, 90 IROC
Engine: 327,LS2,305TPI
Transmission: TH400,STOCK,5 SPEED
Axle/Gears: 373,STOCK,342
Great list! I have a LB9/MM5/G92 1990 Iroc-z in brilliant red ( 1 year only available in that color) 1 of 295 according to that list. It was made 12/1989, I was wondering if anyone knows the vin number of the last Iroc-z ever made?
#107
20,553 Camaros were made for 1990. Keep in mind that this is the only year (for third gens) where technically there were no cars made of a particular model year in the phisical year... If that does not make sense then... There were no 1990's made in 1990 they were all made in the Late summer/Fall of 1989... Thus the limited production run.
AFAIK There is currently no information about which car would have been the last IROC... The best you could do is create a listing of VIN's and work backwards, go to CARFAX and Autocheck and start inputing potential VIN's. Unfortunately the VIN would not tell you whether it was an RS or IROC... FORTUNATELY the engine Code in the VIN will because the IROC was only available with the LB9 or the L98, and the RS was only available with the V6 or the LO3. So if you find out what the Last 8 (L98) or F (LB9) car was made for 1990, then you would also have the last IROC...
The down side is at least 5 percent of the cars would no longer be registered on either service, so unless you got the very last VIN 1G1FP21??LL120553 you may never figure it out...
John
John
#108
Thats a good idea! I never thought of doing that. On the driver's door sticker it say's it was manufactured 12/89. I've read on the internet that no Iroc's were made after 12/89, so it's gotta be 1 of the last few. The last numbers on the vin is 133240 that's a high number vin for a 90 iroc.
#109
I had the wrong data, there were 34896 Camaros in For 1990... The 20553 number was for Firebirds... Sorry...
So you have a very late 1990
John
John
#111
520 GTA LB9/A4
164 GTA LB9/M5
Problem is I am not sure how popular it will be... All of them should have the 2.73 axle. They will have the WS6 which is standard on the GTA.
Actually Leather was more popular than the Cloth on GTA's in 1991. About 73% of all GTA's in 1991 had leather.
Source:
http://www.gtasourcepage.com/91RPOFigures.html
164 GTA LB9/M5
Source:
#113
It really depends, for example the Jamaica Yellow for 1992 is one of the most desired colors, probably due to its rarity. Some colors seem to be less desirable, but it really depends on who you talk to. Most people will take a red car, or a Black car, but it would depend on your location, for example a White car is an easier sale in Phoenix AZ than a Black car. The blues and the greens had some issues with paint peal...
#114
Car: 83SC/84z28 autoform/2-84matrix3
Engine: LG4/L69/L69
Transmission: 5M/700r4
Axle/Gears: 3.73g80 j65 /3.73open
Info needed any way to know how many 1983 sport coupes had j65 disc brakes My car 1983 sport coupe LG4 M5 F41 G80 J65 V08 GT4 3.73 and not many more options. Thanks
#115
7207 is the lowest number I could find in your list of RPO's that was for the F41, which was a SC specific option. I am not sure what all the F41 included other than special suspension pieces, I was not aware that the SC was available with the 3.73, as far as I knew that was a L69 option
#116
Engine: LG4/L69/L69
Checked my cars build sheet last nite it has gt4-3.73 gears in a sport coupe. Thanks for the info.
#117
like I said I was not aware of it... As I think about it I think my 83 SC parts car has the 3.73 drum brake setup... I always thought someone swapped it in... intresting nonetheless...
John
John
#118
1 Post
Car: 1990 Firebird
I've always wondered if the 1990 Firebirds will command a premium, although slight, over the other years due to the lower production run. This isn't reflected yet, but I think it could be in the future. The curse toward collector value of the basic Firebird is the mass number produced, but in a twist that could help those in great shape (to an extent) since most everyone has either owned one or known someone who has. However, I agree that unless you have a personal attachment to your Firebird, it is foolish financially to restore it hoping to make a profit. Mine being my 1st car, I'm slowly fixing it up. On the flip side, I took mine out for a rare ride one day, body halfway through restoration and the interior completely gutted (carpeting included) except for the driver's seat and I overheard a couple of guys in the parking lot comment on what a cool car it was. It is the GM75 (dark metallic red) w/ T-tops, so it really is a beautiful car when fully restored.
#119
Honestly, I lost my crystal ball so I will not be able to tell you the future. What I can do is speculate and give some historical examples to attempt to predict the future.
Look at the first Gens. I do not see a huge difference in price between any of the three years... Personally the trend that I see is the engine and transmission combination, and trim are the biggest contributing factors. There are some things that historically have become virtual truths. 1) The faster the car typically the more it will be worth. 2) The bigger the engine typically the more it will be worth. 3) People typically love options, certain options to be exact. 4) Unusual Factory combinations typically get juices flowing, such as the LB9/M5/3.42 or 3.45. 5)Unusual colors, like Yellow right now seems to be a big draw, it's a trend and will fluctuate from one color or another. Ultimately all of that will depend on the fickle public and the whims of the day.
The point in hand will an Airbag equipped car be worth more than a car without an airbag. For the most part keep in mind that just all Firebirds from 1987 - 1990 were cosmetically identical. There were changes from year to year, all of the changes were not to better the car, but in many cases to keep the cost down on the car... I can give examples if really interested.
However there was an anomaly for the Firebird & Camaro in 1990, that most cars in the GM fleet had not yet seen, the Airbag. Although it was on some of the upper end cars, like Rivieras, and Cadillacs, The problem I have with the 90-92 considers the fit and finish of the bag itself is lousy. Not to mention just about every 90 - 92 F-body I have ever driven the steering wheel moves up and down, like there is something worn out in the column...
Give it or take it... If the car is desired normally, The model year may help a little, For example a 1990 IROC, GTA, Trans Am or Formula, with a 350/3.27, or the LB9/M5/3.45 may see a slight change, but I really do not see a Formula, LO3/A4 being worth more than an 88, or 92 for that matter. The thing that I see is there are not a group of people out there wanting a base firebird, or an RS or SC... I know of many people that would take a Formula over a GTA any day of the week, but the majority of people would prefer a GTA or IROC over all other models. I would personally not get wrapped up into the rarity of the car, At one time I thought that way about my 1987 Formula, until I realized that all Formulas came with WS6, and the LG4/A4 was worth only a little more than a boat anchor. So I modified the crap out of the car and I enjoy it... I am saving my 350 convertible for a good logical reason however.
John
John
#120
Ok my dad wonders if there is many cars like his, It is a 1992 firebird convertible 305 tbi 5spd, It came with trans-am aero pkg but not the T/A hood or tail lights.
Here is the best pic i could find on my computer, you can also see my gta in the pic!
#122
More then most other 83s. It's cool because they had a lot of "first year" options. They don't seem to be super desirable, but it's hard to find them in good shape. Pricing probably falls along the lines of the 84 15ths.
#123
Honestly in the long run I would suspect that the GTA could be worth more than a base Firebird Convertible if everything was equal... may be wrong, but that is my opinion.
John
#125
Ultimately what it boils down to is 1) condition, 2) miles, 3) what someone is willing to pay. This link will give you places to go to start some basic research.
https://www.thirdgen.org/forums/hist...g-what-my.html
#126
There were 46 5spd's installed in the BASE firebird, (does not include Trans Ams) in 1991... Unfortunately it does not break out the number of V6 and LO3 (as the car in question is) with the M5. Nonetheless it is one of the more unusual... dare I say "Rare" Firebirds with the combination... What it does to value is debatable...
John
John
#127
1 Post
Car: Lots of 'em
After reading all of this, it makes me unbelievably happy to have a run of the mill 1986 305 TPI IROC. Considering that 305 has been gone for a very long time, and is currently crushed, or still rusting away in the junkyard.
Last night, I hacked up original door panels, and original carpet. It's good to do a restoration without going by RPO codes.
#128
now don't that make me feel stupid...
Unfortunately I do not have the numbers for the 1992 Verts... I would, however, imagine the numbers would be indeed similar... someone may actually know, it may be on my list and I forgot.
#129
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
#130
I do recall seeing T/A's that were exported with the LO3, and the base tail lights, and the export mirrors, but not the hood. to my recollection. Being that Adore is in WA it could be possible that he has a Canada spec car.. The cars that went to Canada had very similar specs as US cars as far as body components. The only reason for the special tail lights is for those cars that went to parts of Europe... Some of them also had special front fender amber lights that were not flush with the fender, but stuck out so that people could see them blinking when next to you on the road.
John
John
#131
Car: 1985 irocz
Engine: l69 5.0ho
Transmission: 5 speed
Hey everyone ,
Just thought I'd give some info about my car which i think is a little rare. I have a 1985 iroc z with the l69 and 5 speed all wheel disc brakes. It is blue no t tops, no ac, no power anything. The only opotion it seems to have is a trunk release. So whoever ordered it either wanted just a performance car with nothing to weigh it down, with a stickshift. Or was really cheap and couldn't afford the automatic F.I. engine and ac power windows etc. anyways I like it cause its kinda like a stripped out muscle car from the old days . If anybody has any prod numbers of colors and options etc for this years model and engine tranny combo that would be really cool. Also I noticed on the list 2497, 1985 Z28 l69 h.o.'s I have a sales brochure from 1985 for the camaro in it it lists that the l69 was only availabe in the iroc, does anyone know this to be true ?
#132
I believe that is true, that only the IROC had the L69... I know for 1987, only the IROC was available with the L98, so it would not be unusual for them to reserve the engine for the IROC... I checked the White Book (notoiously inaccurate at times) and it confirmed that only the IROC had the L69.
#133
Car: 1985 IROC-Z28
Hey everyone ,
Just thought I'd give some info about my car which i think is a little rare. I have a 1985 iroc z with the L69 and 5 speed all wheel disc brakes. It is blue no t tops, no ac, no power anything. The only option it seems to have is a trunk release. So whoever ordered it either wanted just a performance car with nothing to weigh it down, with a stick shift. Or was really cheap and couldn't afford the automatic F.I. engine and ac power windows etc. anyways I like it cause its kinda like a stripped out muscle car from the old days . If anybody has any prod numbers of colors and options etc for this years model and engine tranny combo that would be really cool. Also I noticed on the list 2497, 1985 Z28 l69 h.o.'s I have a sales brochure from 1985 for the camaro in it it lists that the l69 was only available in the iroc, does anyone know this to be true ?
#135
If you still have one it would be in the center console for a 1985... many of thsoe go mising because they delaminate from the console, get lost or thrown away by the owner as they either do not know what it is or do not care.
John
John
#136
Car: 1985 IROC-Z28
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Any thoughts on the rareness/desireability of Canadian (and export cars)? The reason I ask is that for some years, Canadian cars got some rather interesting options (350 with T-roofs for example).
Also, of course numbers are much lower. My 1988 GTA with LB9/M5 appears as 1 of 378 for that year for Canada (combined number of T/As and GTAs - GM Canada does not distinguish), so it probably is one of about 160-200 actual Canadian GTAs.
#139
The T-top/350 specialty thing was actually 1987 only, at least that is the only year that I have seen the anomoly. Interestingly it was only on the GTA & possibly the Trans Am as Canada has no record of any T-top Formula 350 cars for 1987 or 1988. In 1989 there were tons of Formula's, Trans Am's and GTA's with T-tops and the 350...
Unfortunately compnine does not have any Trans Am or GTA's prior to 1990 in the database, so I cannot look up how many were actually sent to Canada.
John
John
#140
Interesting thing about Comp Nine. I put in the VIN for my Canadian 1988 GTA and it came back with "Vehicle: not listed"; "Build Date: unk" and then gave me a listing of all of the GTA rpo codes that match up with my list from GM Vintage Vehicle Services.
#141
I found that interesting too... I did not know that they had the candadian info on the Trans Am's... It appears to be there, but it does not calculate the number for each RPO in their system like they do for other cars... which is interesting if you ask me.
John
John
#142
Well they are still updating the database, I think eventually they hope to have a majority of the VINs from 1980 to present. Perhaps the data on the canadian cars is some of the data that they have been putting into the computer and they are just not done yet?
#143
I have been in contact with compnine, unfortunately the information they are getting does not cover the Firebirds nor the Camaro's from the 80's... He is perplexed as it is almost omitted intentionally when comparing it to other cars from the era...
John
John
#144
Thats absurd, if the idea is to make money off the data like PHS (even though they probably don't make that much), then the idea backfires as eventually even the lowly Grand Am will reach collector status and all that info will be available for free. Whats the purpose of going to PHS for the info that will be in Compnine. You would need the whole range of cars to make it profitable. If they omit the F-bodies, what does that say about the vettes? Anyone try an 80s vette yet?
#145
Corvettes are not there either... At least not for the few I chekced priro to 1990...
John
John
#146
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
1098 1990 Camaros with the UM6 RPO Radio, mines one of them
#147
Just to add another bit of confusion...I put in the VINs for my second GTA as well as my 1989 Firebird (V6/5-speed) and I get a rpo printout - even with correct color, etc. But again, no build data or production numbers.
By the way, Schorr's "Firebird and Trans Am" book showed up today. Excellent book and thanks for the recomendation (see people actually do pay attention to the posts). Just waiting for the Camaro book to show up.
Gary.
#148
Car: 1985 irocz
Engine: l69 5.0ho
Hey 1985305hol69 sorry it took so long to reply haven't been online in a while. Id send you my spid but I feel a little stupid I'm not quite sure what it is. is it like a build sheet. The other problem is: it's winter here in Canada and my car is in storage I don't have a garage at home so I rent out some dead storage for the winter. I won't get into it until the end of April. Anyways it is still cool to find someone with the same car. What is your interior ? Mine is light grey cloth. The only disapointing thing for me is that someone along the way put in an ugly 80's sunroof. Next time I'll try to get back to u quicker next time.
#149
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
1321: 1984 Recaro Edition T/A
#150
Car: 1985 IROC-Z28
The SPID is in the console glove box, and it has all the RPO codes that the car has, meaning the options and build codes.The ThirdGen.org RPO decoder found on the homepage can tell you what (most) mean.
