PHS's JY 92 Formula 1LE going to BJ Palm Beach!
#152
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: PHS's JY 92 Formula 1LE going to BJ Palm Beach!
As far as being "rare" in reality when you add up all the years from 1988-1992, I would bet at least half of the 1LE cars had A/C... BUT almost all of those with A/C were the B4C Special Service Cars... I am not sure if the Players cars could have gotten A/C or not....
#153
John
#154
I almost wonder if that is why ed Hamburger was using the Formula... Because it was one way to get A/C and 1LE... Oddly enough, he removed the brakes anyways on many of them for the Brembo brakes, so it seemed like a waste if you are taking something off... Kind of like the T-tops and the 350 was only available on the Formula in 91 & 92...
John
John
#155
I'd think there was some decision also made in part by Pontiac/GM. Pontiac had to decide what the package for B4U was going to be and by deciding this was mandated to red/Formula/350/hardtop/1LE only, then at least from Pontiac's point of view, this was their top of the line performance oriented model, that in turn also suited SLP's needs as a base.
#156
None of the Players cars had AC. They were all equipped the same.
#157
In all honesty, the Firehawk, and the TTA were not technically "factory cars" insofar as they were not made at THE factory. Like the Convertibles they were farmed out to another company, albeit with RPO codes, to be converted. So you could argue that they may not qualify.
But you add the B4C Special service cars, and I still bet that you would have more 1LEs with A/C than without.
#158
