'92 RS, what to do?
Car: 92 RS, 87 Formula, 89 IROC, 05 SRT4
Engine: 5.0 TBI, 5.7 TPI, 5.0 TPI
Transmission: 700R4 x2, T-5
Axle/Gears: 2.73, 3.42 posi x2
'92 RS, what to do?
Ok, guys, quick survey: I have a '92 RS 5.0 auto (anniversary edition, not heritage) with about 246k on the odo. It leaks oil from the rear main seal, and I've replaced it several times, but the seal itself slides out of the block. There are a lot of small things wrong with the car, none of which can't be fixed, but
I recently purchased a running '89 IROC-Z 5.0 TPI 5-speed hardtop with frame damage for $500. I believe this is a G92 car.
My question is this:
Should I A) just use the shortblock from the '89 to replace the engine in the RS, and leave everything else original, or B) Use manual trans setup and the top end (roller cam, lifters, and TPI induction) on a 350 longblock, replace the entire drivetrain in the RS and turn it into a Z28 clone? I have no intention of selling this car any time in the near future, so I'm kinda worried about devaluing the car in the long run... but I also want to be able to drive it!
questions, comments, suggestions welcome
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: '92 RS, what to do?
Do whatever you want.
246K miles... Sheesh. That's a TON of miles on these cars. Many cars are trashed at 90,000 miles, and you almost have a quarter of a million miles. Your car has driven the equivelant of about 10 times around the world.
Personally I would not worry about it. I would think you would definately appreciate the extra power of a 350...
Honestly tho, I would not try to clone anything... nothing better than having a sleeper. I would keep the stock exterior of the RS and put the powertrain from whatever car you want... Especially if you are not considering selling it... Enjoy it
Thanks for the input, I think I will probably end up doing the z28 powertrain, and just hang on to all the stock parts, that way I'll take first place in muscle cars at concourse 2040
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
With that many miles, I say do what you want...it isn't like the car can ever be a low mileage original again.
Good luck with whatever you do.
Car: Had 2 iroc-z's . An '87 & '88.
Engine: HAD 5.0 & 5.7 tpi
Axle/Gears: stock
How bad is the damage on the iroc? If its not crushed beyond belief i would fix it. But then again im an iroc fan. and later fix the rs.
but just dont clone it if you decide to take on the task of swaping.
I agree, definitely don't do a Z28 clone -- if anything, swap over all the goodies except the badges. However, I'd seriously consider fixing that IROC instead if it's not that far gone...
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Frame damage is bad mmmkkkay.
Fix up which ever car has the best body. Don't do clones, who says you cant have z28 parts on a RS?
Axle/Gears: stock
Frame damage is bad, but depending how it is, it can be fixed. Its not the only car world with that kind of damage. Tons of people fix cars with frame damage and come out looking and driving like new again.
Lol it's tweaked pretty bad, it was t-boned. We had to beat part of the footwell back out with sledges and cut the door off (notice I said" "cut" deliberately) just to be able to get to the pedals. Short version is the car itself is toast. Also, frame damage on a body on frame car is easy, but unibodies, in my experience, are never the same...
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Axle/Gears: stock
As others have said do what you want, it's your car(s) so you should do what will please you the most.
Unibody cars that get hit bad can be fixed so they are just as good as new body wise. It all comes down to the skill of the shop and the tools they have at hand. My RS was totaled, after a front clip and two stints on the frame machine, the car drives exactly like it before before being hit.
You'll know the shop has the equipment if they have a frame machine that uses laser measurements and lot's of reference points. Figuring out if they have the skill and will apply it is another story.
I had an 86 Sport Coupe that was hit and fixed by different shop without the proper tools etc and it never drove right again.
