UL5 radio delete in 1988
1 Post
Car: 1991 Z28
Engine: 400 ci LS3
Transmission: Jerico DR4
I just picked up a fairly stripped 1988 SC with the UL5 "option". This car has the factory antenna on the fender - identical placement and equipment as my brother's 1991. So, either the fender has been replaced or the car left the factory with the antenna (I don't know how to verify either scenario). If ALL 1988 UL5 cars left the factory without the antenna, then I probably have a car that was hit.
Car: 1983 Z28
Axle/Gears: stock 7.5"
Re: UL5 radio delete in 1988
It was probably there on all of them. I remember buying a 1990 Chevy Cavalier new and it was the VL model with radio delete yet the car had an antenna and all 4 speakers plus all wiring was there for a radio install.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I'm surprised that speakers or an antenns would be included with radio delete because assembing cars is all about saving cost. Wiring, yes because there's less cost in using the same harness for all. But an antenna costs GM $2.00 and a plastic plug costs $0.02.
UL5 radio delete, but has an antenna with a lead
U79 factory speakers with harness
https://www.thirdgen.org/forums/car-...-solution.html
It's easier on the manufacturing process to have all fenders stamped with the antenna cutout. The cost of the antenna was probably less than having multiple fender stamps.
