My GTA RPO Codes
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
My GTA RPO Codes
This are the codes for my 89 GTA I got the description with the RPO Decoder
but need Help Understanding some of them:
T96: LAMP, FOG
K68: GENERATOR,105 AMP
D42: SHADE, RR COMPT SECURITY
A31: WINDOW, POWER OPERATED, SIDE
82D: TRIM COMBINATION, CLOTH, MED DK GRAY ( D) (91 )(1,049 Made in 89)
VK3: LICENSE PLATE, FRT MOUNTING PKG (My car Have The holes bot not the Kit The previus Owner Most got Rid of it)
T93: TAIL & STOP LAMP, SMOKED
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
D3Y: GEAR, SPEEDO DRIVEN
AU3: LOCK CONTROL, SIDE DR, ELEC
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND (What This Mean?)
VAN: ASSEMBLY PLANT, VAN NUYS, CA
TR9: LAMP, GROUP
KC4: COOLING SYSTEM, ENG OIL
DG7: MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
AQ9: SEAT, FRT PASS A DRIV, RECL
7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND (What This Mean?)
U75: ANTENNA, POWER, RADIO
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
DE4: SUNSHADE, REMOVEABLE HATCH ROOF (Dont Have this Another Prev Owner Thing)
AM9: SEAT, RR, SPLIT, BACK, FLDG
6ZX: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND (What This Mean?)
U62: SPEAKER SYSTEM, DUAL COAXIAL
QLC: TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
JG1: SHAFT, PROP, ALUMINUM
DC4: MIRROR I/S, R/V, TILT, DUAL READING LAMPS
AAA: 4-WAY MANUAL SEAT ADJUSTER
NK4: STEERING WHEEL, SPORT LEATHER W/ RADIO CONTROLS
FE2: SUSPENSION SYSTEM, RIDE HANDLING
B84: ORNAMENTATION, EXTR MLDG, B0DY SIDE
W62: ORNAMENTATION, AERO PACKAGE
UQ1: RADIO PROVISIONS, FOR STEREO
NA5: EMISSION SYSTEM, FEDERAL, TIER O
E9Z: SPEEDOMETER KEY (DELETE) (What This Mean?)
B20: ORNAMENTATION, INTR, LUXURY
WW1: APPEARANCE PACKAGE(WHITE), AERO #l
UK3: ELECTRONIC SYSTEM, ACCESSORY CONT
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
E5Z: SPEEDOMETER ADAPTER (DELETE)
B2L: PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
9NL: COMPUTER SELECTED REAR RIGHTHAND SPRING (What This Mean?)
WS6: PERFORMANCE PACKAGE, SPECIAL (Sweet)
UF6: LAMP, INTR, CONSOLE, COURTESY
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
D9B: SENSOR, VEH SPD (What is this?)
BC8: ORNAMENTATION, INTR, DR MAP POCKETS
829: SEAT BELT COLOR, MED DK GRAY (91)
WS4: MODEL CONVERSION, TRANS AM
UB3: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
L98: 5.7 LITER V8 TPI ENGINE (Like )
D81: SPOILER, RR, AERO WING
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
821: INTERIOR TRIM (DARK MEDIUM GRAY)
V73: ANTENNA, FIXED
52P: WHEEL COLOR, GOLD MET (91)
U29: LAMP, INTR I/P, COURTESY
PW7: WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
ILD: TRIM, INTERIOR DESIGN
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
40U: PRIMARY COLOR, EXTERIOR, WHITE (91) (2,961 Made in 89)
U25: LAMP, INTR, RR COMPT, COURTESY
N64: WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
G80: AXLE POSITRACTION, LIMITED SLIP (Me like it)
C49: DEFOGGER, RR WINDOW, ELECTRIC
11Q: MOULDING COLOR, WHITE
UT4: RADIO, AM/FM-ST CASS, AUTO NR, TOUCH CONTROL, STEERING WHL CONTROL
N10: EXHAUST SYSTEM DUAL (I like this One)
GW6: AXLE REAR, 3.27 RATIO (Is This Good?)
CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
Y84: MERCHANDISED PKG, GTA, TRANS AM
UT1: TONE GENERATOR, WARNING
R9R: Not Found (Error)(The software did not have this one)
T96: LAMP, FOG
TR9: LAMP, GROUP
V73: ANTENNA, FIXED
Re: My GTA RPO Codes
3.27 Borg Warners are pretty good....Y84 is special, but GW6 is common with Y84.
N64 is rare. still there?
N10 is dual cat...not true dual.
I think our cars are twins. pm me the last 6 of vin. would like to see how far apart they were built from each other.
Car: Pontiac 89 GTA
No only their but never use, I was under the impression that all Third Gen Have That.
A lot of great information on this site. Only about 90 active users anymore, but still one of my favorites.
http://www.gtasourcepage.com/89RPOFigures.html
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
only thing i can find on R9R is its "control sales item 92" have no idea what it is though
all the springs are "computer selected" from the factory on thirdgens, atleast the later years, its nothing significant
I believe the vehicle speed sensor feeds the ECM
Car: Pontiac 89 GTA
Thanks for the info.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If your car was originally ordered for PR, R9R may have been something to do with shipping to the protectorate, not sure tho
John
John
Car: Pontiac 89 GTA
Car: Pontiac 89 GTA
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Car: Pontiac 89 GTA
Car: 1992 W68 Firebird
Engine: 305 5.0L V8 TBI
BumpaD82
02-26-2016 02:57 PM
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
MikkoV
09-09-2015 04:25 PM
