Players R7U PROM
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Players R7U PROM
For years I have wanted to dissect a Players PROM. So that will be the purpose with this posting. A bit of history on what GM did or didn't do within the race version of the PROM. I am no expert on PROM tuning, rather trial and error. So as I muck through the R7U prom, I'll post up interesting things.
For today ... It's all about spark! The racing PROMS were designed to maximize the engine output BUT keep the engine from destroying itself. The tuning was made for WOT. Have a look at the two graphs:
The overall spark is similar but there is spark removed in the middle (See dip) and then added to the top. At the top, there is 5 degrees more. In the valley in the middle is as much as 7 degrees pulled out.
My guess is at the RPM change in WOT when up shifting or the precursor to that which is when they are going to WOT. (maybe others can chime in) Rather than wait for the "knock", they removed timing. The valley looks to be 1600-3200 range at about 50% duty.
I know over the years of racing, much of the learned calibrations made it back into production. IF you look at the spark curves in 86-87-88 and up you can see the changes from a basic "mechanical advance" to "all in" ARAP vette style, to the R7U approach.
Mark.
PS. As I get time, I'll dig into other areas. If there is something of particular interest let me know and I can look and post up info.
Mark.
Engine: TPI(s)
Re: Players R7U PROM
Other areas I'm looking at at Volumetric Efficiency and Enrich Power ... both appear to have more significant changes over stock. Stay tuned.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Engine: TPI(s)
Ok ... so I find it exciting to dissect the data ... I'm a car geek.
Engine: TPI(s)
I need to borrow a 1989 race PROM and take a read. See what that looks like. Need to ask nicely of a fellow I know a real 1989 R7U still with chip.
Mark.
Engine: TPI(s)
R7U cars had tuned PROMs to promote engine longevity as well as matched for premium gas. shift lights were set at 5100 or so (what GM said was best). While I have not done a quarter mile test between stock and R7U ... the one magazine test that compared a R7U vs. non-R7U showed the R7U was faster in the quarter mile. The PROM was expected to be worth a few tenths. I should find that article and post up ... hmm.
Mark.
If you aren't willing to post the .bin file, would you consider a personal "trade of information? I can trade you a copy of my SLP Performance PROM.
I think between the R7U, SLP, and S_AUJP, you could come up with a great base to start tuning from that would give you lots of ideas where to start...
Alex
Alex
This is a very interesting thread. Would be interesting to see what the performance difference is though testing in car to see what gains the tune gives.
Would be interesting to have a list of what the differences are between the R7U prom and the regular LB9/L98 prom too. Always interesting to see what kind of parameters were changed with this factory GM go fast tune.
Engine: 4++,350 & 305 CIs
I have 2 different SLP chips. Both are 90-92
One is a 305 5speed and the other is a 350 auto
I would like to see the difference from stock they had. (my 89 car went faster w a stock chip and timing/ fuel PSI bumped up over the 89 SLP chip).
That is very impressive, Mark.
How do you read this bar graph?
I would think that the proms would be different for the R7U cars as they would need to be calibrated to match the mods completed to the motor.
My '91 is a 5.0 / 5 speed car and i'm not sure if i have the stock chip or aftermarket. There is no sticker (as I have seen on other threads) on the prom itself to identify it. Is there a way of doing so?
Mark.
Mark.
Engine: TPI(s)
Here is another pic:
Top is R7U. Middle is 1989. Bottom is my hack one.
You will see the big valley in the R7U one which I interpret is where the RPM drops when shifting gears. Rather than let it ping and retard timing, they removed it. No ping.
Well my uneducated guess.
Engine: TPI(s)
The only reason I don't post it up in full is that there are those that will take it and "sell" it. I guess I really don't care ... but I never collected this stuff with intentions on making money. Just fun and interesting stuff.
So I would share with those who want it for their own person interest. Not for profit. Ideally ... someone like me who will compare and discuss what they find. I think we will all will appreciate knowing what GM choose to do in the PROM.
Cheers!
Mark.
Cheers!
Mark.
Engine: TPI(s)
If you want to assist with the decode ... please drop me a PM with your contact details!
Mark.
Mark.
I'm just wondering, if the tuning had anything to do with the different exhaust used?
Engine: TPI(s)
Pull down the ECM (Passenger side behind dash access from bottom - remove panel). Open door on ECM (held on with two bolts). Look in round window of the blue PROM PAC. If it is stock, it will have a sticker viewable through the round opening ... usually with two rows of numbers/letters. Race PROMS had no part number, but had the special yellow engine seal paint on top of the PROM.
I can post a pic of a RACE one if you need to see.
Mark.
Mark.
Car: 91 Firebird
Engine: 6.0
Did the RU7 cars not have emissions (cat, AIR, etc)? If not, then that could account for the difference in the spark table
Engine: TPI(s)
Teams could remove the smog pump in early years. Unsure about the Serpentine setup. I can't recall reading that.
So yes ... less emissions.
Linson
10-01-2015 09:50 PM
