Trans Am/GTA
Car: 1991 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: 3.08
Trans Am/GTA
I recently purchased a 1991. The owner said it was a Trans Am. However, the insurance company is listing it as a GTA. I also have several RPO codes that I can't track down. Any help would be great!
Re: Trans Am/GTA
Transmission: Pro-built 700R4
Re: Trans Am/GTA
Insurance companies like to do that so they could charge you more. There is no way they can determine it is a GTA with just the VIN. As said above, if it has Y84 it is a GTA. If it doesn't, then it is not a GTA.
Re: Trans Am/GTA
Insurance companies can be strange. I can relate. When I first got insurance on my 1989 base Firebird it was listed as a "Formula II." Of course there is no such thing as a Formula II, so I don't know where they get this information. After some back and forth and education, it is now listed as a Firebird.
Car: 1991 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.08
Re: Trans Am/GTA
It is a Y83 car. Thanks for the info. Its a working project.
Car: 1991 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.08
Re: Trans Am/GTA
No. There is only the Y83 on mine. The ones I can't find are: D8M, R92, VAN, V1B, V73, 45Q, 62W, 72W, 8NL, 82C, 82I, 829, 9NL
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Re: Trans Am/GTA
Well if there is NO RPO Y84, Then its NOT a GTA Just a regular Trans am
Regarding your insurance, Back when I had my base 1990 Firebird it had the LO3 V8 and I remember the insurance paper said "1990 Firebird/Formula" .
So since it had the LO3 V8 which was standard V8 in the Formula it rated it as a "Performance Vehicle" $$$ :/
Dave
Dave
Re: Trans Am/GTA
Y83 means it is a Trans Am, not a GTA.
Car: 1991 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.08
Re: Trans Am/GTA
How can I find out about the other RPO's, and what they represent?
Re: Trans Am/GTA
R92 is actually R9Z, some sort of sales control item, not really useful as far as your car goes
VAN - Van Nuys Assembly Plant
V1B - Value Package Savings - not sure what for, though
V73 - Probably fixed antenna
45Q - Molding Color - green metallic
62W and 72W are actually 6ZW and 7ZW, which are related to your front springs
8NL - rear spring
82C and 82I - Med Dk Gray cloth
829 - gray seat belts
9NL - rear spring
Car: 1991 Trans Am
Engine: 5.0 TPI
Axle/Gears: 3.08
Re: Trans Am/GTA
Thank you so much! Hoping that within the next year she will be back to top condition.
