Looking for Silver 1987 FIREBIRD WA Lower Color Number
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I am trying to figure out the WA number for the Silver lower stripe on 1987 Firebirds or Formulas...
The WA number is on the bottom of a SPID. The RPO would be 13L, but I need the WA number...
John
John
Re: Looking for Silver 1987 FIREBIRD WA Lower Color Number
John, as best as I can tell, this is what was going on with code 13 Silver for the 3G Firebirds. Also attached is a Firebird SPID from 1987, 1988, and 1989.
1986 13U Upper WA9021 First year for this color (first year for BC/CC on F-Body)
1986 13L Lower WA9005 per PPG and DuPont, but check SPIDs. May have been WA9021
1987 13U Upper WA9021
1987 13L Lower WA9021
1988 13U Upper WA9021
1988 13L Lower WA9534
1989 13U none
1989 13L WA9534
1990 13U none
1990 13L WA9534
Note: Some paint manufacturer charts indicate GM’s WA9021 as 13S, since at that time Corvette was already using a 13 code for Silver. Corvette’s 1985-88 code 13 Silver was WA7781.
Note: Firebird’s WA9021 Silver was used on the 1988-1991 Buick Reatta two-seater but called Sterling Silver, and also the 1996-2000 Corvette but called Sebring Silver.
Note: After 1988, Silver was not available on Firebird as an upper color until 1995. However, it was a different color, now GM paint code WA9566.
1989 13U none
1989 13L WA9534
1990 13U none
1990 13L WA9534
Received 1,160 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
They are all the same color....(wa9021, wa9534, 13, and 13s) On my PPG system, all of those codes show up on the same formula, so I had just listed the first WA code that it came up with.
Cool! thanks
No problem! Shiftman did waaaayyyyy more research than I did though lol. I just got lucky with a 1 min code search
THETANK
Mid-Atlantic Region
05-08-2009 11:51 AM
paulmoore
11-19-2004 01:42 AM
