6,599 MILE 1986 IROC-Z
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Re: 6,599 MILE 1986 IROC-Z
VIN: XXXXXIROCZ28
8th digit of VIN is an “O” for “Oh my god, it’s a 350!”
Car: '89 GTA
Engine: ZZ6TPI
I don't see anywhere in the ad where it claims the car has a 350. It says 5.0 Ltr TPI.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
DO I see over spray on the tail light trim piece or is this from lighting?
It is a nice looking car, but something smells... Were the original seats that wrinkly on the sides? Also the seat material does not look quite right to me... Maybe I look at too many Firebirds with the Pallex material...
Car: '89 GTA
Engine: ZZ6TPI
I see, well that's good. Otherwise, it seems like a very nice, honest car. Too much money though.
I've also noticed a lot of low mileage original 86' IROC's for sale lately. Most are well optioned and have the LB9, but 86' being the transition year with only the peanut cam TPI available, they will likely bring less money than other years. Seems to be a lot of them around though.
Axle/Gears: G80 GU2
The Black 88 5-speed I put up actually says both in the same ad, and has a “sticker” that says 5.7 TPI on the back.. The engine code is clearly “F” in the VIN and being a 5-speed it’s obvious..
Some people also have a distaste for the high mount third brake light in 1986, but I guess it’s sort of special to that year which could be unique as well..
I agree the 86s seem abundant as of late..
Axle/Gears: G80 GU2
I think the seats look correct.. They are that velour 85-86 seat material.. It had elasticity if I recall and could wrinkle like that..
As far as overspray, good luck getting anyone to take a clear closeup picture to prove otherwise!
Received 1,160 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
I was emailing them back and forth about the car....told them it was a 305, and they changed it.
gatormccluskey
08-05-2010 08:26 PM
