new to site need a little help!
how rare is my car? 86 iroc L69 5speed with 373 gears i think. I was told there were 74 units the same as above, if so what kinda value roughly would it hold. the car is in good shape with 140,000klms but has interior damage and floor board damage when the roll cage was removed. Any help would be appreciated
1 Post
Car: 99 Formula
Axle/Gears: 342
L69 isn't that the HO carb motor, then yes that car is very rare. However, I would check the vin though, I believe it's the 6th Digit. 'H' means you have the LG4 and I'm not sure on the TPI motor.
Your car has a roll cage, anything done to the motor for a roll cage?
To see if you have 3:73s look under your console lid at your RPO codes, if you see G92 then you have 3:73s if not you have 3:23s.
yup! it's carbed. It's engine code G, as for the motor just a coil,moduel and k?n but she pulls pretty hard. I found out the roll cage was there because these cars were built for a road racing series up here in canada.
I would say yes! it is rare to have a carbed car neverming the L69 option at all. You have the most high performance car you could get kind of with a carb on it withourt a 350. It is pretty rare, enjoy it!
Pac J
05-17-2020 10:44 AM
[MN] S&W 8 point rollcage
FueledSoul
09-30-2015 09:18 PM
