[PA] 4th gen clutch pedals answitches with wires
Old 09-18-2018, 12:59 PM
bilsz28's Avatar
Car: 92 z28
Engine: 5.7
Transmission: t56 6-speed
Axle/Gears: 3:42
I have a set of clutch pedals with the switches and pigtails from a 95 camaro these will work great on a 3rd gen t56 swap.$65.00 shipped to the lower 48 states
Old 10-16-2018, 06:34 PM
bilsz28's Avatar
Car: 92 z28
Engine: 5.7
Axle/Gears: 3:42
Re: 4th gen clutch pedals answitches with wires
bump
Old 10-18-2018, 09:24 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Hi. Just curious, but why can't you use third gen manual pedals for a t56 swap? I'm sure i'm not the only one who would like to know. I also have a t56 I will be swapping soon.
thanks, Greg
Old 10-18-2018, 11:57 AM
bilsz28's Avatar
Car: 92 z28
Engine: 5.7
Axle/Gears: 3:42
I just read all the articles about this swap and they said to use gen 4 pedals. I do know the gen3 cars have a push throw out bearing and the gen4 have a pull throw out bearing. I was told you have to use a gen4 flywheel and clutch set up and bellhousing for the gen4 t56 swap. I just did all that because I had a automatic so I needed to get everything to change it over to the t56. worked out well. So the answer is, I don't know if the gen3 pedals will work
Old 11-01-2018, 04:44 PM
bilsz28's Avatar
Car: 92 z28
Engine: 5.7
Axle/Gears: 3:42
SOLD
88FormulaKiller
07-13-2017 10:31 AM
Dante93GTZ
05-19-2010 07:46 AM
FiReBReTHa
12-09-2001 01:12 AM
Quick Reply: [PA] 4th gen clutch pedals answitches with wires
