[RI] Interior Parts -------> Too many to list
Factory Thirdgen Auto-Dimming Rear View Mirror: Here's a quick video of it plugged in and working,............
http://berlinetta.info/video/AutoDimMirror.mov
Not sure what year this was originally from. Had to splice the wiring back together because it was cut and the lens isn't perfect, but the mirror is in good working condition. You can see there's a defect to the glass at the top and bottom edge in about the center of the mirror, it's a used part with scratches and scuffs. $60 + shipping for the mirror, Add another $15 if you need the uncut harness. Will fit into a medium flat rate package, but it's light so include your ZIP code for a Priority mail shipping quote.
Send me a PM if your interested.....
Re: Interior Parts -------> Too many to list
Yes they would Steve, That is the exact same mirror I've installed in all my GM's for the last 20 years or so. I just checked and - even at under 4 pounds - the cheapest shipping to you in CA would be medium flat rate/Insured for $75 = $17.50. LMK if you need any hardware or other small parts that I could throw in the box for Ya'.
Engine: LB9 305
Transmission: AT
Price and availability on a complete factory steering wheel and horn button assembly for my 1989 IROC Z Vert. 94954 Thanks.
PS My 1988 Lincoln Mark VII LSC uses the same , OE, auto-dim mirror in the first photo.
I don't have any IROC Steering Wheels to offer you.
I will post some Steering wheels in this thread in the near future,..... but the only Z28 / IROC style steering wheel I've got is from an 83Z and it's ----> Bad !! Sorry I can't help.
84-89 Camaro lower Hush Panels for AC cars; The $20 pair ( On LEFT ) is pictured in detail below.
Closer pic of the $20 set shown on top LEFT above, Some scuffs scrapes on the pass side + a small "extra" screw hole on one mounting tab,
1 mounting tab hole chipped on driver side. ( Drivers side for AUTO ! )
Clock for sale,... $55 + shipping. Clock was plugged in and kept time for 15 minutes. Adjustment Arm turns and time can be set normally, Lights were working, Wiring pig-tail & Plug included. The very tip of the second hand has chipped off and the plastic lens has been cleaned and quick-polished to remove any heavy scratches. Send your ZIP code for a shipping quote if your interested.
The clock posted in THIS post has been sold.
Last edited by John in RI; 10-10-2019 at 04:11 PM. Reason: The clock that was shown in this post has been sold.
2 Sets of Camaro Front Seat Tracks
$80 + shipping: Restored Used parts, all Springs intact. This set was blasted/painted for a car I sold a few years back but I never used them. Found some surface rust starting to re-appear in a few spots, but their still in real good shape. These WILL need to be lubed-up before installation.
$50 + shipping: Factory used parts, all Springs intact. I'd lube them up before installing them.
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
do you have a 90-92 gauge cluster?
Car: 1987 Iroc Z
Please do. I'm looking to buy one soon. Also, what kind of prices are we looking at?
thanks, Greg
thanks, Greg
$45 + shipping; GM "Twilight Sentinel" Auto Dimming Rear View Mirror with independent controlled duel map/courtesy lights. Used on the mid nineties Chevy and Buick cars ( Impala SS, Park Ave Ultra, etc... ) Includes the correct plug/pigtail and instructions on how to wire it up.
Here's a short video of the mirror while wired up and working:
http://berlinetta.info/video/AutoDimMap.MOV
THIS PPD was SOLD: others available.
$155 + shipping: 86-91 Hatch Power Pull Down Assembly. pulled from a 91 and it has the small power plug. All 4 guides are completely intact so the PPD assembly doesn't "rattle" like they do when the guides are bad. This unit is fully functional & includes the optional hatch release solenoid ( also tested and working ).
Here is a short video showing this PPD assembly in action. http://berlinetta.info/video/PPD.mov
Car: 1983 Z28 T-tops
Engine: 350 GM Crate
John do you have a turn signal lever? My 83 Z28 from Arizona has a lot of brittle plastic from the AZ heat/sun!
Is that power mirror switch for a console, or a door panel?
Dholland17: Here is a pic:
AtlantaTA: The Power mirror switch is the same for all Thirdgens. It can be mounted on the door or the center console as long as the proper Bezel is used. Camaro switchers are Black and Firebird switches are Grey.
Are any of the hush panel available ? If so how much to ship to 21234 Md. ?
Quick; I checked and the only 82-83 Firebird shift bezel I've got is for an Auto. ( Sorry ! )
Z03 & Tyler; I'l check into those hush panels this evening and will get back with some info once I can inspect them. I should still have a few pairs available. I'll also check on the black belts too !
Z03Z28: I do still have the pair of hush panels that are pictured above for $20; however, the shipping quote from the Post office is $27. ( Package is 5 pounds and 25x16x6 inches. ) Priority Mail is the only option available,... your to close to RI for "ground" shipping.
Tyler: I did find other hush panels too,.... would be a bit more due to being in better condition. I HAVE NOT inspected the others yet because I haven't been able to access the seat belts yet. ( The wife started ripping up the kitchen floor and I HAD to jump in to get that unexpected little project rolling !) My next update will be the availability of any black belts as well as details about the hush panels for You.
TylerSteez (10-12-2019)
Hi, John.
Do you have some original paperwork for these cars? In particular, I'm looking for a dealer envelope labeled "Chevrolet Commitment to Excellence" (among some bowtie symbols).
I could send you a photo of what I'm looking for, if you have something close.
Thanks, John
Thanks, John
(SOLD) Sony CD Player + 4 Pioneer Speakers; $125 + shipping. CD Player works great, Rated for 4-8 OHM speakers, AUX port and USB port both functional, removable face, Remoter control included. You'll need a cheap installation kit so the radio will fit into the Camaro / Firebird bezel properly. Includes wiring harness for plug-&-play fit 89+ style radio plugs. ( adapter can be bought / used for earlier "large" style radio plugs )
Sony PN = CDX-GT640UI
Pioneer Speakers =
TSG4641R 4x6 100 Watt Peak ( 20 Watt nom) 4 OHM
TSG970M 6x9 240 Watt Peak ( 40 Watt nom) 4 OHM
User Manual for the CD player can be found here: https://www.manualslib.com/manual/21...page=14#manual
Video of system plugged in and working:
Include your ZIP code for a shipping quote.
Pioneer Speakers =
#44
88 Firebird Steering Wheel: $35 + shipping. Horn Pad has a tiny 'nick' & the Grey color is faded to black in a couple spots. I've had good results with these steering wheels after a good cleaning and dye job.
#46
Car: 92 Camaro RS
Engine: 5.0L V8
Quick question...what size hole does the clock fit into? I'm going to cut a hole for a cup holder insert.
#48
Camaro Coupe "base" cluster: $45 + shipping; I've had it in storage for at least a decade. Untested and sold as is, I Just don't have any way to test this,... Almost sure it came from the 87 Sports Coupe I owned back then. Post your ZIP code if you need a shipping quote.
#49
Yeah, that's the White one for 82-89. There is a guy on here that is parting out a 92 Z28.If he doesn't have it anymore, I'll come back to you. Even though you don't have the bezel for it, which will be hard to find, I'll get this switch from you. Just in case, my zip is 46168.
#50
Car: 1985 Firebird
Engine: 2.8 V6
Transmission: Automatic
Hi!
Would you happen to have a driver’s seat belt receiver in grey for an 85 Bird? Mine takes about 20 tries before it will latch!
Also, the light assembly for the license plate?
