[TX] Late 91-92 Hatch Motor
It’s a weird request, but I need the pull down motor like the bottom right of the photo below. All I really need is the internal contacts to be intact and working, but I’ll take the whole motor.
I managed to grab a new reversing switch, but one of my motor’s contacts snapped in half before I ever had the car. It’ll work enough for a couple cycles until the broken contact slips out of position. And I’m in the middle of nowhere Texas and the closest junkyard burned down several months ago. Thank you
Re: Late 91-92 Hatch Motor
I appreciate that, but everything that I have works. It took a while to figure out, but the only issue that I have now is one of the small metal block shaped contacts that energizes the motor split into two pieces. The motor will push and pull the latch up and down correctly until that broken block slips and gets caught in the rotation.
