What door panel is this?
Old Mar 24, 2007 | 04:20 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
I found this door panel at the junkyard in a firebird I think while I was looking for a steering colunm. I really like the style of that door panel and would like to add a set to my RS. But they were trashed so I didn't get them. But what year did they come on and what models? So when I am ready I know what to look for. Thanks in advance! Adam :-)
Old Mar 24, 2007 | 06:08 PM
Sickcuban's Avatar
Car: 1984 Camaro
Engine: LG4 305 - Conversion Commencing
Transmission: TH700-R4
Axle/Gears: 4.10
Re: What door panel is this?
that is the GTA "deluxe" door panels...idk what years
Old Mar 24, 2007 | 06:25 PM
MNformula350's Avatar
That is the Firebird 85-89 Deluxe door panel option. If you want to put a set like that on your car, you will need to make sure you get the metal bracket for the arm rests, as they are specific to this style door panel.
They are not "GTA" door panels, they could be had on any Firebird, Formula, Trans Am or GTA from 85-89.
The last 2 pairs I have seen or pulled were form an 87 Formula and a 86 Firebird.
Old Mar 24, 2007 | 10:46 PM
Ok thanks guys. But since it's a "Deluxe Option" how rare are they. Can I still find some later or should I take those and try to use them. I should go get the metal brakets though so I have those atleast. What I want to do is have the panel black. And do the insert tan to match the seats. Adam :-)
Old Mar 25, 2007 | 01:18 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Haha, ironically I just removed those exact same door panels off my 87 Trans Am for regular black door panels. Mine are in better shape than those. I am almost positive they are fiberglass. They certainly are not that cheap carboard crap!. Lucky you, I took pictures of the door with out the panels so you can see what kind of mounting bracket you'll need. Enjoy.
Attached Thumbnails What door panel is this?-metal-door-1.jpg   What door panel is this?-metal-door-2.jpg
Old Mar 25, 2007 | 12:27 PM
So ummmmm. What are you doing with the panels you took off. lol. Adam :-)
Old Mar 25, 2007 | 09:35 PM
HCR13's Avatar
Car: 1987 Trans Am
I'm not sure yet, I'm not going to keep them. They aren't mint. The door panel itself its in pretty good condition, but the vinyl needs to be cleaned up, or more advisable, replaced. The center cloth piece is also falling off. I haven't taken pictures or I'd post them.
Old Mar 26, 2007 | 12:31 AM
If you can, snap some pictures. I might take them off your hands. Adam :-)
Old Mar 28, 2007 | 02:54 AM
HCR13's Avatar
Car: 1987 Trans Am
I'll try to take some pix tomorrow. The only difference I've noted is that I had electric windows, so there isn't a hole for the manual lever...
Old Mar 28, 2007 | 08:14 PM
Cool. Let me know. Adam :-)
Old Mar 28, 2007 | 08:32 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
They are made of some sort of MDF basically, def not fiberglass. I have 2 sets, one of them the bracket pulled off that holds it to the door. I just used some 2 part epoxy to hold it on
Old Mar 28, 2007 | 08:44 PM
HCR13's Avatar
Car: 1987 Trans Am
Ok, here are some basic pics. I have more detailed pics aswell if you're interested I can email them to you. I can also take pics of any particular part if you'd like.
Attached Thumbnails What door panel is this?-dscf1643.jpg   What door panel is this?-dscf1647.jpg   What door panel is this?-dscf1653.jpg
Old Mar 28, 2007 | 08:56 PM
HCR13's Avatar
Car: 1987 Trans Am
one more... Upon closer inspection, I did see that they aren't fiberglass, but they sure seemed like it...
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
