shifter plate repair automatic
Old Jun 6, 2010 | 02:43 PM
qcworm's Avatar
Car: 1987 IROC Z-28
Engine: L-B9
Transmission: 700R-4
can you replace the slide part of the shifter plate, someone broke the slide out of mine and i found a plate with a good slide but broken corners, so can this be done , i am asking before i go tear my car apart but it has to come aprt, right?
Old Jun 6, 2010 | 07:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: shifter plate repair automatic
It can be taken out - just be very careful. I replaced mine, but I hated the notches in it (collected a ton of dust, impossible to clean) - so I went to the art/craft store, and bought a black plastic art portfolio for $5, cut out a chunk the right length/width, drilled a small hole and then cut out the right sized hole for the shifter ****, and installed that. It looks great, and best of all there's no dust collection now!
Old Jun 8, 2010 | 02:16 PM
my82roc's Avatar
Car: 89 Iroc Convertible
If you have the earlier style shift plate without a moving indicator then its easy to do.The slide piece does exacty that...Slides in and out without a problem.Very easy fix
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
