shifter button has cracks and I wanna know how to remove it
Old Aug 7, 2010 | 10:58 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My shifter in my 92 RS has developed cracks in it, and I wanna know how to remove the **** with out buggering it up, so I can replace it. any help would be appreciated...
Old Aug 7, 2010 | 11:10 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: shifter button has cracks and I wanna know how to remove it
There is a small flat clip on the front side (closest to the dash). Use a needle nose to pull the clip, **** will lift right off.
Old Aug 7, 2010 | 11:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If it's auto with square shifter ....Put key in, turn ign to on, pull shift lever all the way back into 1 - look on the radio side of the shifter, you'll see a staple - pry it out (small screwdriver) and the **** will come right off the stick.
Old Aug 8, 2010 | 08:00 AM
Thank you. Now I just need the plastic button. I'll check w/ dealership.
Old Aug 8, 2010 | 11:29 AM
Car: 1992 RS
Engine: Carbed 350
I think they are replaceable with a 4th gen **** as well - I'm pretty sure the leather one I got off ebay to replace my OEM vinyl one is a 4th gen **** - it's a tad longer (goes a bit farther down the rod) than my OEM one, and it looks identical to the **** in my 1997 Z28.
I see them on ebay all the time (the entire ****, not the button) - not sure the button is available alone.
Old Aug 8, 2010 | 11:59 AM
I just need the push button part. I wonder if the 4th gen button would fit?
Old Aug 8, 2010 | 12:56 PM
Car: 1992 RS
Engine: Carbed 350
It should - I can see no physical difference between the **** I installed in my 1992, and the factory **** in my 1997.
Old Aug 8, 2010 | 01:25 PM
Well, that's good news. I could find one from a car being parted out, or maybe just... maybe GM may still stock it.
Frozer!!!
Jan 19, 2024 04:55 PM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
