Will my speedometer work
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Alright everyone, thought I would post this up and hopefully get a response. I have a 92 Z28 and I converted to carburated, I removed the computer in the process.
I am installing some cyberdyne digital gagues and I need to know if my speedometer will still work without the computer.
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: Will my speedometer work
If it's an electronic speedo, and you have the yellow buffer box, then yes it will work. There is a write up on the tech articles of Thirdgen on how to wire it. I did the conversion on my '83 Z28 for an electronic speedo, and it's never had a factory ECM in it since I've owned it. I'm running the same circuit now on a '94 instrument cluster, and it works great.
