Instrument cluster question & help needed
Old Feb 6, 2012 | 08:57 PM
bobinphx's Avatar
Car: 84 Camaro & 06 Softail
Engine: 305ci
I am new so bear with me here, please.
I have an 84 base Camaro that has the dummy lights and huge gas gauge. I just got a Z instrument cluster, and am hoping that I can just unplug the old and plug in the new and have at least the speedometer, tachometer, and gas gauge work. Is this a possablity, or what do I need to do to get the new cluster to work? Hate not having tach or gauges.
Thanks ahead of time for any info.
Old Feb 7, 2012 | 07:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Instrument cluster question & help needed
No plug and play.
Instructions below:
https://www.thirdgen.org/gauges
BTW, welcome to TGO, bob.
JamesC
Old Feb 7, 2012 | 03:08 PM
bobinphx's Avatar
Engine: 305ci
Thanks James, even though I have the 85mph speedo gauge package, I now know it should work after changeing the sending units. Another project.
Old Feb 15, 2012 | 03:38 PM
chrispy383's Avatar
Car: 92 rs 25th ann.
Engine: 383
Axle/Gears: 342
You dont have to change sending units for speedo. If you didnt have a tach you will have to run a signal wire from the dist. to cluster. A wireing diag. will show what pin # to run it to. The other gauges will need sending units and wires ran to cluster as well.
Jeremys87
Jul 14, 2022 09:08 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
