Recaro seat adapters.
Car: 87' IROC
Well I tried to find a set of OEM Recaro T/A sliders but was unsuccessful. So I decided to make my own. These allow the use of the OEM Camaro sliders with the Recaro seat. These are made from 1/4" 7075 T6 aluminum. If you want to make your own, its up to you do determine the correct material and thickness. I am NOT responsible for anything that happens if someone decides to use my design. It is NOT intended to be copied, these are for REFERENCE only.
For the correct result, make sure you print this on 11x17" or larger paper with NO SCALING. Use the provided standards to verify the scale of the print out.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: Recaro seat adapters.
Post pics when you put them in. I love the Recaro T/A seats; best 3rd gen seats IMO.
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Very nice seat and you did a heck of a job making those bracket, They look very professional .
Car: 87' IROC
Thanks guys there is nothing fancy about what I did. These were made with the template, a jig saw, sander, and drill press.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Interesting, you made your brackets run across the seat. Do you have any issues with the Diaphragm bottoming out on the bracket when sitting in the seat? I was worried about that so I designed my brackets to run up along the sides of the seat, Though I had to use spacers to allow the sliders to sit level whereas your design eliminates the need for them.
Engine: LB9, LB9
BTW, who did you have recover your seats? I'd like to recover and refoam my Recaro LS seats eventually to match my interior better.
Car: 87' IROC
I suspect the diaphragm may contact the bracket. It is close, I'm really not sure how much it gives with a person in the seat. With that said, I have sat in the seat for a few minutes and I do not notice anything weird. The good news is it would only touch at the front and back. Not much weight on that particular location.
Before I even started looking at the seat, this was my original idea. I like the one piece.
Car: 87' IROC
http://www.jjcustominterior.com/Home_Page.php
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Thanks for showing us this. I hadn't even looked to see what was necessary to bolt mine up yet. I knew I 'needed' the adapters but the only set I found I can not get in touch with the guy. I decided then that I would be making my own. I like the way you did it and will do something very similar when I do mine. The idea of going across the tracks may be ideal for many people and definitely helps make it easier to make even if the seats were wanted to be higher.
Good Work.
Good Work.
Car: 87' IROC
On thing I should add is that of my two Recaro seats. One had 6mm mounting holes and the other had 8mm holes. The mounting bosses are the same, so I drilled and tapped the 6mm holes out to 8mm. The brackets have hole sizes assuming 8mm holes. Also, the Recaro mounting holes are supposed to be 16" apart, side to side. One of mine was about 1/32" over 16" and the other was about 1/32" under 16". So make sure to measure your seats and adjust your holes accordingly.
Thanks for pointing that out. I would have probably made the two sets the same and never double checked till trying to put it together. I like to use just the right size hole so it could make a difference.
Engine: LB9, LB9
The seats were done by Ron at JJ Custom Interior. He specializes in old Recaros. He is a small business and they took a long time to complete. But for me the wait was worth it. He is very open to all kinds of custom options. I am also having him make a set of netted head rests for that full 80's effect.
Car: 87' IROC
Good deal. Let me know if you need any other info. For an idea of options: Mine are heated, will have a lumbar bladder (back ordered), has a provision for an anti-sub belt, and I will have both the normal (shown) and netted head rests.
COTM Editor
Your seats look amazing! Your interior guy does some amazing stuff for sure. Can't wait to see you bolt it all together.
I contacted him to do a set of seats for me. I think he is about the only one that gets the Recaros right. I am in NY and I have to send them out to him, but it is well worth the cost and effort.
I have a question for you though - why is the seat back release on the inside of your seat?
Car: 87' IROC
I haver a question for you though - why is the seat back release on the inside of your seat?
GPSkinzhut's are probably the same way.
Wow - I didn't know they had them that way.
BTW - I have a spare set of the Recaro seat adapters. They are nothing special - it looks like a piece of rectangle steel with spots to mount them to the seat and brackets. Very crude IMO and I think yours look better. I am not sure if the brackets are just standard thirdgen pieces but I would suspect that they are. The original recaro seats do sit low and I find that I have more head room in an original set of thirdgen Recaros as opposed to standard thirdgen seats.
I can get some pics if you want. I just picked up this set of Recaros so I didn't have them when you were looking for them. I could have taken some measurements for you to go by.
Car: 87' IROC
I can get some pics if ou want. I just picked up this set of Recaros so I didn't have them when you were looking for them. I could have taken some measurements for you to go by.
Car: 87 IROC Z, 2010 2LT
Engine: 305 TPI, 3.6 V6
Transmission: 5-Spd, 6-Spd
Axle/Gears: G92 3.45
Some do have them on both side, but not mine. mine came out of a VW from the look of it. The VW's have the recline adjuster on the inboard side so the release would be on the other side. So technically I have my seats swapped side-to-side. Not really an issue for me though... long arms.
The rails I used came from a recaro T/A, very basic adapter and should be stock, though I don't have a frame of reference to verify.
That's them - i have the adapter that is sandwiched in between the seat and the tracks. The tracks were missing from the set I bought. I suspect the tracks to be standard thirdgen tracks. I can't see them tooling up a separate track for the recaros. That is probably the reason for the adapter. 87350iroc - if you want additional pics I don't mind taking them.
Engine: LB9, LB9
Car: 87' IROC
And if you are interested, I might be interested in buying them from you. I am also looking for the seat belt guides if you have them.
The seat belt guides are standard third gen pieces. I think I have also seen them on 2nd gen cars. I will take a pic of the ones on my seats. The unique part is the metal that is mounted to the headrests where the seat belt guide mounts to. I am not sure if it is a separate piece. I will have to take a look. Give me a day or 2 and I will snap some pics of all this stuff.
I had this pic in my Photobucket. This is one of the Recaros going back in my car. You can see the metal bracket attached to the headrest. The seatbelt guide attaches to that.
These are the seat belt guides it uses. They are listed for second gen F bodies.
http://www.fbodywarehouse.com/fbw/pr...9&bestseller=Y
Car: 87' IROC
Of course one would assume that 82tarecaro would be right about recaros which he is, but I searched a while back and looked at any and all pics of the recaro seats in third gens and all the pics showed the second gen seat belt guide. This was a relief to me as I need them myself. I am glad to actually have it confirmed tough.
If any one has a round adjustment **** for the side of them please PM me. I do not want to hijack this thread.
Car: 87' IROC
Are you referring to the recline ****?
My seats being universal, also have the ***** on both sides. Now they rub on the center console, so I will be removing my inner two and converting the seat to side specific. I'm not sure if Ron wants the ***** back, but if not, I'd be happy to send them to you. And if he wants them back, I'm sure you can order a set from him. He has all kinds of extra parts, side plates, adjusters, ect...
Yes it is the recline ****. One of mine is broken. If you are keeping them then please PM me with a price etc so I can get them from you.
The information for the adapter plates and guides is very informative and I am sure others have been curious too.
I love the Recaro Seats because to say factory Recaro Seats make people think. Most people do not know about them except enthusiasts. I didn't before becoming a part of TGO. For me they are very comfortable also.
Well - I have a set of Recaros in pieces and i have my good set out of the car. If you guys want pictures of anything, let me know. Ron is a great resource for Recaros. I think if you guys need parts he would be the one to contact. He is busy, and it can be a challenge getting in touch with him. But if you are thinking of getting a set done, he is the man to talk to.
I will get some pics of the adapters. I have to dig them out.
Car: 87' IROC
Picked up the netted head rests and my center console arm rest last weekend. Love the netted head rests, 100% 80's.
#48
Car: 87' IROC
Also,
If anyone wants a set of the seat brackets let me know soon. I may be making a set or two from Ron. The more we get the cheaper they are. Price would probably be $170.
John
John
#50
Those came out sharp. I'll have to drop Ron a line and see if he can add that to the list. This interior is never gonna get finished if I keep adding to the to-do list.
