Center console switch and connector id
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
This is just laying loose. I see that it is a switch and it is broken. What does it do? Are replacements available?
This 6 pin connector (pictured just in front of the shifter) was not connected to anything. Is it not used on all cars or am I missing something?
Re: Center console switch and connector id
The switch is for your console compartment light. Not sure where to get a replacement.
The other connector looks like one of the radio harnesses. It appears to be the harness with the power leads.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I think the six pin connector is for the auto tranny shifter. Was this car converted?
The console compartment light switch you will have to get off eBay or somewhere.
Engine: 305 (LO3)
Still pretty sure that six pin is for the auto tranny shifter. I don't remember my 5 speed cars having it on the harness, but could be different for other years. There isn't anything else there on firebirds.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
That appears to look like the UQ7 Sound System Harness.
Wrong one,sorry,I thought you were looking for the top pic.
Double check the SPID sheet to make sure it is a factory 5 speed. I think it should have MM5 listed for a factory 5 speed.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
