Go Back  Third Generation F-Body Message Boards > Tech Boards > Interior
Reload this Page >
Question on removing the instrument cluster from 89 Trans Am?
Old 03-13-2019, 09:15 AM
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Trying to do the odometer gear fix on a TA, I have the clear plastic off the cluster.
Do I remove the gauges from the white cluster piece at this point, just leaving the odometer, or do I remove the entire cluster / white plastic compartment as a whole with all of the gauges still intact?
Once the entire compartment is out, then remove the odometer.... And yes, detect the cable at the back before removing either way.
I find tons of posts for a Camaro, which it appears the gauges in it just push into tabs on the white compartment...the TA appears to have a film the gauges push into from part/pics I see on eBay and such.
2QUIK6 is offline
Old 03-13-2019, 12:31 PM
kentuckyKITT's Avatar
Car: 3 T-Tops
Engine: 327/305/305
Transmission: TH350/700R4/700R4
Axle/Gears: 3:42/2:73
Re: Question on removing the instrument cluster from 89 Trans Am?
Your 89 should be electronic with no speedometer cable. You'll need to remove the entire cluster from the car. There are several 7mm bolts that come out and the whole cluster will pull out. Once out, remove all of the gold screws and the clear plastic and black shroud will come off. To remove the odometer assembly, look for 3 silver screws directly behind it on the backside of the cluster (this holds the circuit board), then 3 gold screws which hold the speedometer assembly in also on the back side of the cluster. From this point, the whole assembly and circuit board lifts right out and you are ready to begin. See the how to step by step instructions on the odometer gears website and a member alan91z28 how to on this thread:https://www.thirdgen.org/forums/inte...ken-but-2.html
kentuckyKITT is online now
Old 03-13-2019, 07:39 PM
Awesome! I did not know it was electric, that makes things a bit easier for sure!
Thanks you very much for the info on how it comes out! Yes, that is the thread that lead me to find the solution for the gears and purchased a set, I have the instructions from their website but could not find anything on how the cluster comes out in a TA and feared I might break something trying to pull it out...you know how things that have been together for 30 years tend to stick together and need a little pry to get apart!
Thanks Again! Will be trying to do the rest of this over the weekend.
2QUIK6 is offline
Old 03-13-2019, 08:04 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Don't forget to unscrew the trip odometer peg, if you don't, you could break the cover plastic lens, which can be quite fragile. It has a head on it that just unscrews just like a screw would....
427seven is offline
Old 03-13-2019, 08:44 PM
Yep, its already off along with the clear lens, that is where I stopped yesterday and posted not being sure how the rest comes out!
2QUIK6 is offline
Old 03-13-2019, 09:31 PM
427seven's Avatar
Well, yer about dun then. After the lens is off, just lift the black plastic bezel off
427seven is offline
Old 03-13-2019, 09:32 PM
427seven's Avatar
Take these out
Just like this
Then turn it over and find the three screws right behind the speedo
427seven is offline
Old 03-13-2019, 09:33 PM
427seven's Avatar
Then take the three screws off the top
427seven is offline
Old 03-13-2019, 09:34 PM
427seven's Avatar
NOW yer dun....
Turn the pod back over and gently pull the head and the electronic package out...
427seven is offline
Old 03-13-2019, 09:52 PM
Awesome, great pics! ...not quit dun...I think the install of that little gear and the drill/tap and assemble part make get the best of me
2QUIK6 is offline
Old 03-13-2019, 09:54 PM
Just curious, do you have a pic of the entire back of the cluster? Just wondering how all of the circuitry is connected to the wires behind the dash..how they connect to the circuit board.
2QUIK6 is offline
Old 03-13-2019, 10:38 PM
427seven's Avatar
Is this what you mean?
427seven is offline
Old 03-14-2019, 08:37 PM
Yes, exactly! Interesting, no wiring harness plug to disconnect, just those push in tab things.
Thanks so much for the pics!
2QUIK6 is offline
Old 03-15-2019, 07:39 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
When I pulled my cluster and realized that it just "sits" against those edges of the printed circuit board, I said to myself, it will never work!
But it does.
DynoDave43 is offline
Old 03-16-2019, 02:18 AM
QwkTrip's Avatar
Car: '89 Firebird
Engine: the broke kind
Now that you have the gage pod out it is a good time to clean up the electrical terminals. Take a pencil eraser and gently clean the tabs on the green screen, and clean the electrical terminals in the connectors at the dash.
QwkTrip is offline
Old 03-17-2019, 10:06 PM
I didn't get the gauge cluster out today, got busy with some other things while it was nice outside for once...hope to get it out one day after work this week and start on the odometer fix. Everything is super clean, car only has 28k miles but will check out the connections.
2QUIK6 is offline
sheltonw3
03-06-2014 12:18 PM
Kornis
09-01-2013 03:35 AM
Chuck84TA
01-30-2013 12:29 PM
igotmailed
10-03-2008 09:45 AM
v8_musclehead
03-31-2008 11:02 PM
Quick Reply: Question on removing the instrument cluster from 89 Trans Am?
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
