Steering column, need help
Old Oct 31, 2020 | 01:53 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Hi folks
Took my Formula 350 on nice 2 hour round trip today, it was GREAT!! Howver as I came home I noticed my steering column is loose. Right where the adjustable steering joint is. See pic below. Anyway I can grab the steering wheel and make it move around freely in any direction, and its getting a bit worse when I play with it. Something is either loose or worn out. Before I tear it down just wanted some input. I have rebuilt this same column back in 1990 but I dont remember all the parts, etc. thanks.
The red circle is the area where its loose.
Old Oct 31, 2020 | 04:02 PM
Engine: 5.7
Axle/Gears: Stock
Re: Steering column, need help
So this is called the steering wheel wobble. I just order a pin pulling tool so I can get in there and tighten the 4 bolts. Found info here and in a google search.
Old Oct 31, 2020 | 05:23 PM
OrangeBird's Avatar
Car: 1989 Firebird
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
Hi Hawkeye1980 , this is the best on line tutorial I've found regarding our steering column , I used it to rebuild mine when the "Stub shaft" went bad ....
PS , page 14 is where the bolts your after are addressed .
Old Oct 31, 2020 | 08:43 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
https://www.thirdgen.org/forums/susp...-rebuilds.html
Old Nov 2, 2020 | 11:30 AM
Engine: 5.7
Axle/Gears: Stock
Thank you QwkTrip! Will check it out!!
Old Nov 2, 2020 | 11:34 AM
Engine: 5.7
Axle/Gears: Stock
Thank you as well OrangeBird!
Old Nov 2, 2020 | 11:37 AM
Engine: 5.7
Axle/Gears: Stock
YEARS ago, say 1990 I had a 1971 CJ-5 I did a complete restomod on. One as a Saginaw power steering conversion. I used this same column in the that conversion. I had to rebuild the upper half and all this is coming back to me. I even have most of the tools need to fix this. I remember thinking I had to keep these tools if I ever had to fix another column..Especially on my fairly new 1989 Formula 350 back then. Here I am...31 year later.
Old Nov 2, 2020 | 11:38 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Look Here! Plenty of pics/parts/instructions :
www.steeringcolumnservices.com
Old Nov 2, 2020 | 11:50 AM
Engine: 5.7
Axle/Gears: Stock
thank you sir!
Old Nov 3, 2020 | 07:41 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Yes, common problem and not that hard to fix. It's been a while since I've done one as well, but if I recall correctly, the only special tools you need are a steering wheel puller, lock ring compressor and pivot pin puller. Use some locktite on the 4 bolts so they don't back out again.
Old Nov 5, 2020 | 08:00 AM
Engine: 5.7
Axle/Gears: Stock
Yes I have most of those already. When I get to it I will update. thanks!
Old Nov 5, 2020 | 08:37 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I remember having to do this to my car probably 15 years ago. I also used loctite then, and its still tight today.
Old Nov 7, 2020 | 10:37 AM
Engine: 5.7
Axle/Gears: Stock
Good to know thanks!!
Old Nov 8, 2020 | 04:01 PM
Engine: 5.7
Axle/Gears: Stock
Well its pretty much done. The big connector at the bottom of the column got wedged up and i have to pull it out. But the wobbling has been fixed. used Red loctite. My 4 screws were mail torx, not female torx. I had 3/8" sockets but it was to wide to fit. So I used a small 1/4" hex socket and that did the trick.
I noticed I dont have the black plastic cover that go over the metal lock ring. Do I need that and if so anyone have one? thanks
Will put up some pics later.
Old Nov 8, 2020 | 04:44 PM
Holy crap, there is no need for red on this. Purple, Blue, or even Green would have sufficed.
Old Nov 8, 2020 | 05:43 PM
OrangeBird's Avatar
Car: 1989 Firebird
I agree , since red needs heat to release it for removal , and it'd be pretty hard to heat these bolts given their location , it's together forever now ....
Old Nov 9, 2020 | 11:14 AM
Engine: 5.7
Axle/Gears: Stock
ok RED
Farrens
Feb 8, 2013 06:56 PM
dealerkiel
Mar 30, 2008 09:28 AM
WillSpeedy
Jan 6, 2007 08:17 PM
chad1966
Jan 16, 2006 10:56 AM
