[For Sale] TPIS LT1 HEADS PORT MATCHED INTAKE WITH INJECTORS TRADE!!!!!!!
Hey guys,
I have a set of lt1 heads worked up real good by TPIS, they run a 1278 felpro, portmatched lt1 intake with 36lb ford injectors and a AFPR, the intake is also ported to 58MM on the TB
I do have the flow sheet from TPIS, Also have ard rocker studs and guideplates installed, with LS1 springs,
also have a comp cam for it.
LOOKING TO TRADE FOR l98 stuff.. ie long tubes.. heads.. 700r4 10bolt rims.. and so on.. will upload photos of heads tonight along with flow sheet.
have over $1600 into these.
In sycamore IL 60178
Re: TPIS LT1 HEADS PORT MATCHED INTAKE WITH INJECTORS TRADE!!!!!!!
What are you looking to get out of these for a price? What exactly are you looking to trade for? Can you give me the flow numbers, cam spec and hp this set-up made on your LT-1
Sanjay
08-12-2015 03:41 PM
