[Wanted] Ls1 or Ls6 Crankshaft... Need one (12552216)
I need an ls1 crankshaft. preferably 24 tooth reluctor wheel, preferably standard rod & main journals. If its an ls1/ls6 crankshaft it will have gun drilled mains.
Let me know how much you want for it.
As a heads up the lq4 & lq9 cranks are balanced differently and *do not have gun drilled mains*. Please make sure it's a real LS1 crank and not a truck crank; If you send me pictures I will be able to tell you which one it is. I know the part #'s interchange; but you will be able to tell what crank it is if it does or does not have the gundrilled mains.
Thank you for your time.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: Ls1 or Ls6 Crankshaft... Need one (12552216)
Ive got a load from the machine shop turned down and the undersize bearings to go with. Whats one worth to you?
Also have a bunch of early/late rods, and a few LS1 pistons to replace the one that spun for you
