[For Sale] 5.3L Aluminum Long Block, 799 Heads "L-33" Engine
Car: 86 Iroc
Engine: 355 carb
Transmission: WC T5
Hi all,
I yanked this engine out of my Silverado over the winter to drop in a 6.0 build. It ran fine, no smoke, and had 110,000 miles on it. It did have a bit of piston slap when it was cold as most of these trucks get. Truck is a late 2005, so it got the aluminum block, and 799/243 casting heads, 4.8L flat top pistons for higher compression, and a slightly larger cam than the iron block 5.3. I bought the truck with 30k on it, and am religious with fluids and maintenance. I was going to drop this into an 88 IROC I have laying around but can't seem to find the time with all my other projects. Located in northern NJ for pick up - or I am willing to ship this at your expense. Looking for $800 obo.
--Rob
--Rob
Car: 86 Iroc
Engine: 355 carb
Transmission: WC T5
Re: 5.3L Aluminum Long Block, 799 Heads "L-33" Engine
Cam Sensor is in the back. Its a 24x wheel. This is a Gen3 engine out of the extended cab full size truck - basically an aluminum block LM7. No DOD provisions.
Car: 86 Iroc
Engine: 355 carb
Transmission: WC T5
I'd prefer to sell whole. If it does not go, I'll need the heads to build it.
Car: 86 Iroc
Engine: 355 carb
Transmission: WC T5
Re: 5.3L Aluminum Long Block, 799 Heads "L-33" Engine - Price Lowered to $600
Price down to $600. This tripping hazard needs to get out of the garage. I am willing to ship this.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I'm interested if you still have this and you would be willing to meet part way? I live in PA (17866). Thanks!
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Dammit thats what I need to rebuild me 02
Guys out here think they are gold plated and want a fortune for a worn out motor
Car: 86 Iroc
Engine: 355 carb
Transmission: WC T5
Price drop to $500. I'm moving...this thing needs to go. Willing to meet halfway, up to about 150 miles per person (300 total). I don't check boards often enough. Call or text. 973.454.4948. Rob
Car: 86 Iroc
Engine: 355 carb
Transmission: WC T5
bump. Likely hitting the Carlisle Corvette show in 2 weeks outside Harrisburg PA if that helps anyone with delivery.
