LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[Sold] PSI LS3/T56 Harness LSX Conversion Swap
Old 03-08-2018, 08:33 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
'08 - '14 LS3 (6.2L) STANDALONE WIRING HARNESS W/T56/TR6060 Uses E38 ECM, CORVETTE PEDAL, LS3 MAF
Part# HAR-1037Had this Harness on my thirdgen camaro for a few months, kept having an intermittent dead pedal issue that I couldn't track down. Decided I would swap the harness after trying a few other things. Needless to say its not the harness, my car still has the same problem. With that being said I don't need 2 harnesses. These are $569 new. This is in new condition and comes with the wiring diagram paperwork and lists needed parts. Only modification I did was to the coolant sensor connector. I changed from a 2 wire to three wire to operate the stock GM gauge. I still have the two wire that can be spliced back in. This is long enough to route through the fender opening and back into the stock ECM location. $400 shipped.
LEEEZARD7
06-11-2012 06:34 PM
Slow94Formula
12-31-2011 12:43 AM
88_Import_Slaye
02-05-2006 10:52 PM
Kingtal0n
07-12-2004 05:21 PM
Quick Reply: [Sold] PSI LS3/T56 Harness LSX Conversion Swap
