Starting problems
Old May 28, 2005 | 09:49 PM
Deaclen's Avatar
Car: 91 camaro Z28
Engine: LT4 Intake & Heads bottom end 94
Starting problems
Alright i have my LT4 getting spark and fuel but won't start i have the wires hooked up right i think for the clutch for my 91 camaro so it should fire right up and everythign is gettign fuel checked the enjectors and they are firing and if i spray a bit of starter fluid in there she fires right up and will run as long as i have sparyed it in there fuel pump is brand new so i know it is keeping up with it and i am getting about 45 pounds of pressure what's the deal guys any ideas
Old May 28, 2005 | 11:09 PM
TexasLT1's Avatar
Car: '92 RS
are you positive you're getting fuel? if you are getting spark and fuel you will at least get a sputter. have you removed the optispark or replaced it? make sure you've got it installed correctly. get a code scanner and see if you've got any codes.
Old May 28, 2005 | 11:24 PM
Deaclen's Avatar
Car: 91 camaro Z28
yes getting fuel and the opti is keyed on it so so only goes on one way
Old May 28, 2005 | 11:49 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Sounds like a vats problem .....gotta love it
I'm glad I had mine taken out of the PCM.
Or the fuel lines are hooked up backwards.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
