LT1 carb swap I got a few questions
Car: 1991 firebird formula
Engine: 5.8
I have a few questions swapping an lt1 to a carb.
When looking for a manifold is the bolt pattern the same as the 86+ heads?
What do you do with the opti when you go HEI?
Dose an lt1 have timing tabs?
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 carb swap I got a few questions
You will get rid of the opti all together fab up something to cover up the hole or GM offers one to cover it up.
Most people that I have seen go to carb use the ATI balancer.
IMHO unless the motor is missing the FI set up you are better off with the FI or stay gen 1 and you have a lot more head and intake options.
Engine: 5.8
I just assumed that if people use LT1 intakes on their TPI motors does anybody know of any other intake manifolds other than the GM performance parts one.
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
No, you have to use the GMPP manifold, I believe there is another company that makes one also. it would be easier to keep it EFI and cheaper if you have all the parts.
