Walbro 255 LPH inline pressure
Old Mar 9, 2013 | 01:40 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
Do I need to put an aftermarket fuel pressure regulator or will the OE one do the job?
Old Mar 9, 2013 | 01:42 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Walbro 255 LPH inline pressure
What is your induction? I see it says 4bbl, if so you don't have a regulator.
An adjustable one is good, esp if you have or plan to do any more mods.
Old Mar 9, 2013 | 01:55 PM
Car: 1984 Z28 T-TOP
Wow, I need to update my stuff. Swapping to lt1. Hence the need for the inline fuel pump.
Old Mar 9, 2013 | 01:56 PM
Car: 1971 Camaro
Engine: 427
I would get an adjustable one for sure.
Old Mar 9, 2013 | 01:57 PM
Car: 1984 Z28 T-TOP
Updated!
Car: 1984 Z28 T-TOP
While we are on the topic, fuel filter before or after pump?
Old Mar 9, 2013 | 01:58 PM
Car: 1984 Z28 T-TOP
And check valve to prevent draining back into tank?
Old Mar 9, 2013 | 01:59 PM
Car: 1971 Camaro
Engine: 427
Both according to most fule pump makers these days. Course filter before, and a fine filter after.
That way you keep big stuff from damaging the pump without causing it to strain pulling through a fine filter.
Thats why the factory puts a strainer on the pump and a fine filter after.
Car: 1971 Camaro
Engine: 427
I don't think a check valve is required.
Old Mar 9, 2013 | 02:00 PM
Car: 1984 Z28 T-TOP
I am keeping the original fuel sending unit w/screen in tank. Will that work for the course?
Old Mar 9, 2013 | 02:01 PM
Car: 1984 Z28 T-TOP
Could I burn out the pump if is drains back into tank. Uphill driveway.
Old Mar 9, 2013 | 02:02 PM
Car: 1971 Camaro
Engine: 427
I would think so.
Old Mar 9, 2013 | 04:31 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
I used my stock sender and got a 255lph pump. and added a vented gas cap. I did alot of research when I did mine and its a pretty easy process.
codeysabatini
Nov 10, 2015 04:07 PM
eustodp
Sep 20, 2015 05:09 PM
R13_Braz
Sep 18, 2015 05:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
