LS1 Swap Crew: This is my Supercharged LS1 swap thread
#201
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Re: LS1 Swap Crew: This is my Supercharged LS1 swap thread
I will have to see how the exhaust plays into that. I may not have room, if the aftermarket arms are larger.
#202
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
I used a jester and it gave additional room at the drivers side of the y-pipe and merge area
#203
Car: 89 formula 350
what do you mean by Jester?
#204
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Jegster ... same concept as Bmr Track pack
#205
Car: 1987 iroc
Transmission: 700r4 with shift kit
Axle/Gears: 3.08
how much hp are you going to be pushing when its all said and done?
#206
Car: 89 formula 350
hope for 600-650
#207
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
That would be sweet!
#208
Nice Build!!! Sorry to hear about the fab bill. I can't wait to see a dyno vid of it... I like the whine and power of a Maggie
#209
Car: 89 formula 350
I emailed them today for an update and havent heard back yet....hopefully soon!
#211
Car: 89 formula 350
Found some other pictures. The engine shop had an open house this past weekend that I wasn't able to make it to
Pics from the open house can be seen here
https://www.facebook.com/media/set/?...6556840&type=1
#213
Car: 89 formula 350
yeah I just noticed that tonight. I'm already running a pro kit! should I really go with sportlines?
I'm really really hoping that a spring was installed wrong when they put the k member back in.
#214
1 Post
Car: 92 Z28
Engine: Boosted LSX
deff. looks way to high to be a lowering spring already. Im sure you did loose a lot of weight off the front.
Id consider a global west weight jack setup. This way you can get the stance you want.
#215
Car: 89 formula 350
doing some searching, there is about 100 pound weight difference from a dressed sbc to a dressed ls1. Add 80 pounds for the blower and all the parts, and its about the same.
I'm thinking a spring is installed wrong.
#216
Car: 92 Firebird
Probably hasnt settled down yet. Take it around the block and look at it again
#217
Car: 89 formula 350
its been sitting for about 3 weeks now. it should have settled.
#218
To settle it has to move around.. But also it is 150 lbs difference between sbc and LS1 (and by adding the blower you are removing the previous intake manifold so I think your front end is alot lighter than you may think)
#219
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
I agree with pocket, drive it for a few weeks and then look at it again and see if you really don't like the stance.
#220
Car: 89 formula 350
I think you guys are crazy if you feel the springs will settle 2+"
#221
Car: '88 Iroc-Z
Axle/Gears: 3.23 posi 10 bolt
Mine sat higher than I thought it should after my swap. I thought I would need to lower it in the front, but after driving for a couple weeks it settled quite nicely. I'm no longer concerned. I didn't do before & after measurements, but I think it rides where it was before the swap.
#222
Car: 92 Firebird
No need to go a few weeks. Take it around the block and over a few bumps. A mile or two tops
FWIW, I have basically the same setup as you, +65lbs for my iron block. Pro kit up front stock springs in the rear. Looks as close to stock ride height as I can manage. I tried the Pro kit springs in the rear, but it looked like it was launching perpetually
#223
Car: '89 Camaro
I wasn't saying to wait a few weeks that the springs would settle more, what I meant was a few weeks to make sure that you don't like the stance before you spend the money on springs.
#224
Also FYI... when I swapped to an LS1, I used eiback Pro Kit, and the stance, IMO, was great. Level too.
When I put my LQ4 Iron block in, I expected to see a change in the front. I havent seen any difference, and it has a few miles on it. I also didnt tighten anything until weight was on the front end.
Mine always settles pretty much all the way after I drop it and roll it a couple times to unbind the tires. It certainly doesnt need to drop more than 1/2" though.
Car looks great! Have em check the spring index and maybe it'll drop where its supposed to.
J.
J.
#226
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Seen your car on pcm 4less on fb. What u do with the mini ram and 195s
#227
Car: 89 formula 350
that stuff was all sold months ago
#228
Car: 89 formula 350
Guess that leak!
#232
Car: 89 formula 350
how the hell does that even happen?
#234
Car: 89 formula 350
they said that it is NOT because of the porting...so what else could it be?
#236
Car: 89 formula 350
they said it was likely a "bad casting" and they've seen it before....
Originally Posted by PCM of NC
This is in no way related to the porting and polishing, as that area is far away from it. It is most likely just a bum casting where the material is too thin. We can try putting thread sealant on the bolt and see if that takes care of it. There are also cooling system tabs available but we are not keen on using those. A third option would be to try welding it all up and redrilling/tapping the hole. If this were my car I would probably start with putting thread sealant on the bolt and seeing how that goes. How would you like to proceed?
#237
or someone put a bolt in there that is too long and cracked into the water jacket. Check the others, thread a longer bolt in by hand and measure how much depth you get and how much you have till the header flange and compare to what you had in there.
#238
how much porting was done? The reason that I'm asking is that those 799 heads are plentiful and cheap. Unless you've got big bucks into the porting, I'm not sure I'd want to fool around with that head. If it indeed is a crack somewhere and not just a "poor casting", then slapping a little thread sealer in there isn't going to make the problem go away. At the very least I think I'd want to pull the head off and take a much closer look, perhaps with a boroscope so that I could see what it looks like on the other side. Doing that to verify that there isn't some sort of a crack would at least give peace of mind so that you wouldn't always retain doubts in the future.
#239
Car: 89 formula 350
from the research I've done, its a common issue. I have about a grand into PP work with advanced inductions
#240
1 Post
Car: 92 Z28
Engine: Boosted LSX
Ive seen tons of castings like that. Every MAKE has one if not mre then one bolt that runs into some kinda port. DSM (talons , eclispe) have exhaust studs that go into the oil port. a big WTF. if you dont seal em with something that will leak oil.
get some ARP thread sealant , and drop a Tab in the cooling system
GM Part #3634621. GM has been using this stuff for years on the factory built cars.
or get some Alumaseal its a good product also. Ron Davis (radiators) even said it would be fine and wouldn't worry about it clogging up his radiators.
#241
Car: 89 formula 350
The thread sealer worked! They drove the car a bunch today and started tuning.
The bad: the oil pressure sender broke. They fixed and relocated it, but it leaked onto the clutch and its slipping. They pulled the transmission to look at it.
The good: it sounds mean!
#244
Car: 89 formula 350
Anyone want to guess at the initial HP numbers and PSI its hitting?
#246
Car: 89 formula 350
14psi...should give you more to guess with
#247
615rwhp?
#248
Car: 89 formula 350
657rwhp!
jazzdadss (01-22-2020)
#249
sick man, sounds nasty as hell too.
