LS1 to TPI air box
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
LS1 to TPI air box
What kind of coupler are you guys using to connect the LS1 throttle body to the mass air and then to the TPI air box? My motor is relatively level so it has somewhat of a sharp angle to the air box... Would like to keep it factory looking if possible, instead of building an actual cold air intake.
Car: 89 IROC-Z
Engine: 355ci SBC
Re: LS1 to TPI air box
Fantastic, exactly what I was looking for... Thanks for shooting me in the right direction!
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Do you happen to have a part number for the bellow with the IAT sensor? I am having a hard time finding one.
Thanks!
Thanks!
Can you post a picture of what you ended up with? Thank you
Car: 89 IROC-Z
Engine: 355ci SBC
I went to Lowes and bought a 3" pipe coupler and trimmed it at an angle to fit the air box. Used the stock LS1 bellow between the throttle body and MAF. Fits great and looks good too. This coupler came with two clamps also... <br/><br/>Its rubber and black so it doesn't stand out. Cheap and easy fix till I figure out something better.
I used that intake set up for a month and it choked the flow. http://www.siliconeintakes.com/diy-c...n_shipper.html
Go here and piece together a better one.
Car: 1988 Iroc-Z
[VA] Tpis Mini Ram intake
p-balin432
02-16-2016 09:43 PM
