Torque arm Bushing
Old Feb 21, 2018 | 09:25 AM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Torque arm Bushing
I was wondering if I can bolt the torque arm directly to the Holley crossmember without using the bushing? As the pic shows, there isn't much clearance to the output flange.
Old Feb 24, 2018 | 04:27 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
Re: Torque arm Bushing
no, it needs to float in the bushing... it is a tight fit. see post #20 in my thread below as i needed to work through this as well
https://www.thirdgen.org/forums/ltx-...-ls3-swap.html
Old Feb 24, 2018 | 08:13 PM
TJQIROC's Avatar
Engine: 6.2 Gen V
Very informative post. Your problem was the opposite of my problem. You needed to add spacers. I need to move to the left, or trim the bushing. I need to find the diameter of the adapter flange and trim down the bushing to fit. I am using the stock torque arm which is pretty thin where it connects to the cross member. I should be able to trim the bushing down by about a third and still have enough meat left to do the job.
Old Mar 2, 2018 | 12:29 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Call Holley tech and confirm but most mounts the arm goes on the left (as looking at your picture), which gets in to the trans tunnel. This requires a big hammer to correct.
Old Mar 2, 2018 | 10:13 AM
TJQIROC's Avatar
Engine: 6.2 Gen V
The arm looks like it will mount in the correct location. There would be no problem with a standard slip joint driveshaft. It was not made for a flange driveshaft. That is why I need to modify it.
Old Mar 4, 2018 | 08:02 PM
Car: 91 z28
Transmission: 4L60e
I stand corrected, correct location is to the right (as looking at the picture).
https://www.holley.com/products/exha...ts/71222005HKR
ls1>*
Feb 1, 2010 11:51 PM
dave mc
Sep 5, 2009 04:28 PM
Pablo
Jun 1, 2004 11:08 PM
vegaken
Dec 4, 2003 08:45 PM
