lt1 swap
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
lt1 swap
What motor mounts are needed to put lt1 in our cars.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: lt1 swap
I assume you are referring to the 93 though 97 Gen 2 LT1? If so than normal small block chevy mounts will suffice. The spacing and location is the exact same. If you mean the modern LT1 (Gen V) than that is a different animal all together.
Re: lt1 swap
Sbc will work.
Post up a swap thread if you can,I love seeing LT1 swaps. I wish I had put up pics and a thread when I swapped mine.
blackgold84
02-03-2011 05:43 PM
