My 91 Z28 build. 17 years in the making... Finally going to do this right
#151
Re: My 91 Z28 build. 17 years in the making... Finally going to do this right
Looks good buddy, please stop using inter shield wire lol it’s brittle, not intended for what you are doing... can your welder run gas shielding
#152
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Who says flux core wire welds are "brittle"? That can't be true at all, since all stick welding is flux shielded so....
#153
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
No my welder can't run shielding gas. Please point to an article or book that explains how it is weak. I would like this thread to not run off track into weld style and strength, but if you have legit data that could be useful to me and others please post.
From all I have read flux core is messy, not weak.
#154
Engine: LS3
The LS3 and T56 will be in some new location with regards to the trans tunnel and I wanted to finish the underside coating so I figured the best idea for now was to close up the hole and repair all the hacking I did when I was a kid.
Hole to fix.
Patch panel made and final fitting.
Welded in and all closed up.
Hole to fix.
#155
Engine: LS3
Time to close off the rear frame arches finally.
Hole prepped for patch fitment.
Patches made from some 1/4" steel plates.
All welded in.
Shot showing the muti layers of steel in this area. Makes it hard to weld. Going to leave it like this and use seam sealer for the rest of the gaps after paint.
Small holes and sheets of steel that need to be tied in.
Tinny filler panels made.
I welded them in and then repeated on the PS of the car. I will update when I can get more images.
All welded in.
#157
Engine: LS3
No galvanized here. Just plain carbon steel.
#158
Car: 89`RS
Axle/Gears: 2,72
This is one of the most impressive threads I ever read!
Thanks for sharing all the good info with that much pics.
#161
its brittle, its not intended for use in a vehicle, its and industreal aplication such as ark welded, its the sheilding and rate of cooling that creats the issue
#162
Car: 92 Firebird
Engine: 4.8 LR4
Without some sort of documentation supporting that I am going to call BS that is "not intended for use in a vehicle". I did some searching and couldn't find anything to support that claim
dennisbernal91z (04-24-2021)
#163
The most malleable welds are welds that are heated up slowly and cooled slowly which is what Oxy-Acetelyne is. Oxy-Acetelyne also requires no shielding. Unfortunately it also causes lots of warpage on thinner metals and is somewhat dangerous which is why most people have abandoned it in favor of processes that contain the Heat Affected Zone much better. Flux-cored welding is the same principle as MIG welding and it's performed in the exact same fashion and they've both been an accepted practice for decades. There are a few differences in the welding technique of Flux-cored vs MIG and if the welder doesn't know them they're Flux-cored welds can suffer from porosity or slag entrapment. Is that why you think the flux core isn't allowed? Some weld joints for certain applications will not allow for MIG or Flux-cored because of the penetration vs the thickness of metal so they call for TIG or maybe spray transfer/arc, Is that why you think Flux-cored isn't allowed?
#164
im not saying its not allowed per say, im saying its brittle, but yes thats a couple reasons, as well as cits rate of cooling causes a more brittle weld when used on sheet metal or other thin materials. i have a few books somewhere ill have to dig up, ones on metallurgy and ones specifics of each procedure for welding different thicknesses and different scenarios
#165
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Wow man. I remember this car from many many years ago. Glad to know you still have it. I just picked up another one.
#166
Engine: LS3
Still ticking...
Massive delay in the project due to a divorce, move and now I bought a C7 Z51 as a new daily so I am getting used to that.
Car is still on rotisserie, now at my new house. Work will start up again soon in a more major way. Stay tuned. Now that I have the vette, chances are this car will become more of a crazy show piece (air ride, etc...)
#167
I'm curious if you had seen that car's (C7) sticker price drop as a result of the new C8 mid-engine corvette becoming available. Many people's opinions seem to be that the C7s and higher end C6's will see a big sell off as a result of prior owners selling them to purchase a new C8.
#168
Engine: LS3
My plan was to wait for the C7 prices to drop after the C8 hits the streets. Then I learned that the C8 will only be offered with a dual clutch. This made me nervous because I thought this might make the low miles M7 C7s prices go up, or not fall. Especially Z51s.
I searched and found an amazing deal that I could afford, so I dropped the hammer.
#169
Engine: LS3
FINALLY back at it.
Long delay adding a second full bathroom to my house myself.
Anyways, picking up where I left off. Coating the entire body in 2k epoxy primer. First coat on the final (PITA) rear section done. Second coat going on today. Progress feels amazing.
Just before. Sooo much sanding and scrapping to get all the OEM undercoating off. Then Fast Etch, then clean, clean, clean before painting.
Still drying.
Still drying.
#170
Engine: LS3
Time for an update. Work is happing on a much more regular basis now.
Time to finish all internal welding. This involved adding the harness attachment bung to the cross bar. Hole drilled.
Bung fit into place before welding.
I also got around to finally removing the windshield. Folded it up into thirds and tossed it. Able to clean up a few rusty areas under the glass now.
#171
Engine: LS3
How the car looks spun back around after doing a nice thick coat of epoxy primer over everything on the inside. Now to finish off non-critical exterior areas.
Engine bay can finally have its smoothed out firewall panel primed. Prepped and ready to go.
Rear rotisserie removed so that I could access the tail light and rear frame rails for priming. Sanded with 120grit and ready to go after A LOT of blowing dust off and out of the garage.
#172
Engine: LS3
Here you can see the interior after a long time coming, all patches redone and metal work done (for now), in primer.
You can also see the braces I made to accept the rear passenger shoulder seat belts that are welded to the mini tubs.
Smooth out panel primed. Filler work to come next before it gets another coat of primer. Gonna do my best to keep the engine bay SUPER minimalistic so that smooth firewall really comes thru.
Nothing exciting but the primed rear tail light section. Nice to see these easy to ignore areas getting attention.
#173
Engine: LS3
Next step is to sort out my fender situation. Aftermarket fenders are known to be garbage so I decided it is best to try and fix the pieces I have.
One was badly damaged when the car slipped off a hydrolic jack in the rain, trying to push the car around by the jack.... 2013 me made some stupid choices.
Below you can see the main damage. Note that the car's lower mounting ear for the fenders rotted away so when I had a shop paint the car back in 2006 they tack welded the fenders in place...smh...
Time to fix this. Problem was I don't even know what these mounts look like or where they go. That is why I wanted new fenders since I knew these mounts were mangled up on the fenders.
After a few hours of my very first time metal working using some HF hammer and dolly, combined with vice grips, pliers and screwdrivers, I got the damage fairly sorted.
Once it is all sanded down and primed, then filled, it will look good. Also, you won't be able to see any of this under the GFX.
With the mounting ears correct enough on the fenders, I can now see where this lines up on the body and weld on some attachment points. No more tack weld!
#174
Engine: LS3
Added the fender attachment points. Made from double layered 16 gauge. Also removed the tack welds from the car and fenders that used to what held on the lower attachment points. Can finally move onto SFC. Need to measure car for straightness first. Plan to weld in BMR outer SFCs and add more bracing tabs to tie them to the floor along their length. Not 100% sure how I will do this exactly, but I do know I won't just be relying on the front and back attachment points.
PS
DS
PS
DS
#175
Engine: LS3
A bunch of images of the SFC install. You can see the added plates to tie into the rocker seam. Think I am going to scuff them and paint them with epoxy primer so they blend in with the rest of the underside.
Pic
Pic
#176
Engine: LS3
dennisbernal91z (03-05-2021)
#178
Engine: LS3
I'll post again once I have it painted.
#179
Axle/Gears: 10 Bolt 2.73 Open
I can hear those squeaks and rattles running for their lives now...
#180
Engine: LS3
Final shot before prep and paint on the SFCs. I'm going to scuff them up and paint them with the sane epoxy primer, along with 30 small touch ups the floor needs before flipping it back and starting on the interior.
Surprise: gonna do something I have never seen done on a third gen.... stay tuned!
#181
Engine: LS3
Finished painting what could be coated with hvlp gun last night. Will use sponge brushes to get some nooks and crannies later.
DynoDave43 (03-14-2021)
#182
Engine: LS3
#183
Engine: LS3
Day one of dash design. Cut out everything I'm not using. Dakota digital dash stand in, in place. Seats are back ordered till late June so sitting on a bunch of moving blankets to figure out how far in to set them. Currently 32" from my eyes. Can anyone check their car, is 32" about right?
#184
Engine: LS3
Seats will be Corbeau RXX in black.
Dash will Dakota Digital VHX-1023 in black.
Steering column will Ididit with tilt in black.
Steering wheel will be Billet Specialties (still deciding) either gunmetal or bronze.
No radio, no AC.
Vintage air windshield defrost and floor heater.
Custom fiberglass door panels and dash pad and all interior plastics to cover fuel cell trunk and mini tubs.
No radio, no AC.
USMC3782 (04-06-2021)
#185
Engine: LS3
Starting to lay out dash after cutting out old gauges and vents. Developing an action plan here is a job in itself. I've never done anything like this.
After some brainstorming I think the plan of attack will be customize the dash pad first. This gives a good reference line for the dash. I also picked up some materials to start making block off plates. MDF.
Car will not have a radio so speaker grills are being shut along with upper vents. Car will have defrost and floor heat from Vintage Air.
#186
Engine: LS3
Dash pad fabrication.
Sanding dash and masking speaker block out plates.
Will be running Vintage Air windshield defroster and floor heat. 3 season show car.
Inserted MDF into dash to build up vent delete area.
#187
Engine: LS3
Another shot of vent depression delete.
Window defrost vents closed too. Plan to have windows open most of the time. You can see the defroster vents temporarily hot glued in place.
Under side with healthy application of short strand filler to lock everything in place.
bluegrassz (04-14-2021)
#188
Engine: LS3
Didn't take a pic of the dash with MDF block off plates and filler, but I am sure you get the idea from the underside and previous pics.
Felt installed and stapled down. Lools fairly decent just like that, haha.
Here you can see some of the dozens of staples keepimg the felt on. It is also held on with spray on adhesive.
bluegrassz (04-26-2021)
#189
Engine: LS3
Resin applied to felt
Fiberglass cloth applied over another helping of resin, then more resin on the cloth. Pic is after initial sanding of final resin.
First few applications of filler to get the realy low spots of the glass smoothed out.
#190
Engine: LS3
"Rundo" applied. Mixture of filler and resin. Something like 60% filler. Applied with a brush.
Just about dry
Showing inside Rundo application
Also some additional filler here.
#191
Engine: LS3
Rundo sanded, getting really smooth now.
#192
Engine: LS3
2 coats of very high build primer
Guide coat
#193
Engine: LS3
Guide coat sanding
All the touch ups needed
Tacked off and ready for final primer, normal high build
#194
Engine: LS3
Filler panel for center vents
Dash coming along. Slowly making filler plates and brackets as well as fabricating the left side of the dash to mirror the right.
#195
Engine: LS3
Corbeau seats! Getting close to test fit time so I can design the center console and door panels.
Brackets
DS didn't fit. In my opinion donor car they used to design them was messed up. My car, to the best of my knowlgde is straight and crash free. PS and DS dims match for mounting studs. Corbeau has a different dim for front DS spacing. This is wrong. After a call to them, concluded that drilling out mount hole for 2 holes by 1/16" will do it. It worked.
87CIZ (08-20-2021)
#196
Engine: LS3
Some images showing progress on the dash. Wood blocks add structure. Short strand bondo beginning to fill in voids and lock things in.
#197
Engine: LS3
Fiberglass resin used to close holes on PS. Rough shaping of MDF board at transition. Starting to feel very solid.
#198
Engine: LS3
Various images of fitting the universal flaming river column.
#199
Engine: LS3
Notch cut in dash. First seat check!
#200
Engine: LS3
Everything seems like it is going to work
