My 1984 Trans Am is Finally repainted in Platinum! Lots of pics!
Old 10-18-2010, 10:02 AM
  #101
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: My 1984 Trans Am is Finally repainted in Platinum! Lots of pics!
Originally Posted by roper88cars
How mutch space do you have from the rear tire to the trail arm or anything else. Could you have zero ofgfset and make it work? What about an 18 inch rim with 9"width?
there is plenty of clearance behind the rear wheels.
Converting between backspacing and offset can be difficult at times. For my 9" wide wheel, it's 9" wide from the inside of each lip and pretty much 10" wide measured from the outermost parts of the wheel. This means that if my wheels were 0 offset, it would effectively have 5" backspacing. Since they actually have 4 7/8" backspacing right now and just barely clear the tie rod, pushing that edge back another 1/8" is pushing it. It's right on the borderline. If there are wheels you really want to get with those specs, I'd say go for it and get some very small spacers (1/8" to 1/4") if you end up needing them.
Going to a larger diameter wheel won't hurt any clearances as long as the overall diameter of your tire is still the same (25.5" - 26" for our cars).
Old 10-18-2010, 10:55 AM
  #102
roper88cars's Avatar
Originally Posted by Brennan
wow man, beautiful car
Jeremy, can we see som pics of the Engine compartment and the smoothed fenders?
Old 10-18-2010, 11:00 AM
  #103
Former Sponsor
1Aauto's Avatar
I love those wheels on that car,great choice.
Old 10-20-2010, 05:45 PM
  #104
JeremyNYR's Avatar
Car: 1984 Trans Am
Here are pictures I just went out and took of the inner fenders. The lighting sucks, but you get the idea. Notice no bumps from where the tanks mount and the top lip of the strut tower was smoothed too.
I've been wanting to trim down and put loom on those wires for a while now, and I want to do something about the nasty looking alternator and its bracket too. It's so hard to get EVERYTHING done that you want to on a car.
Old 10-21-2010, 10:21 AM
  #105
Nice Jeremy, So you have no windshield wahser tank anymore and what of the Overflow for the radiator? Do you just route the hose to dump on the ground since it is more or less a short trip car now vice long distance/show car? I was thinking about that as well. i do not need the windshield washer unit either.
Old 10-21-2010, 11:10 AM
  #106
JeremyNYR's Avatar
Car: 1984 Trans Am
I have a small black overflow bottle strapped to the passenger side of the radiator, you really can't do without that because the coolant expands when it's hot and needs somewhere to go. It's only like a quart and could stand to be a bit larger, but it works. I don't have a washer fluid bottle. I was planning on hiding a small one, but haven't gotten around to it. Honestly, I probably wouldn't ever use it anyway.
Old 10-21-2010, 11:49 AM
  #107
How did you mount your batery in the back? Is it in the car or under the car on the outside. Pics of that by chance? Thank you for your time by the way.
Old 10-21-2010, 02:20 PM
  #108
JeremyNYR's Avatar
Car: 1984 Trans Am
it's mounted behind the little storage door on the drivers side in the hatch area. I got a kit that included a metal tray and the cable. The tray is bolted into the rear frame rail that runs right under there and it's held down with a plate across the top and 2 threaded rods running down (all part of the kit). I'll have to see if I have pictures showing when I installed it. You're very welcome. I spent a lot of years on here reading and asking questions so it makes me feel good whenever I can contribute.
Old 11-14-2010, 09:23 PM
  #109
F-Body Demon's Avatar
nice man!
Old 11-15-2010, 09:01 PM
  #110
Moe87's Avatar
You should get the wheels' spokes painted the same color. Similar to the black or golden spoke of the stock birds. Would really accent and match the wheels a lot better.
P.S. i actually like the original color too!
Old 12-14-2010, 06:11 PM
  #111
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
It is not an enclosed kit?
A friend of mine relocated his battery in his 69 camaro. He now has a lot of corrosion inside of his trunk around the battery, going into his second restoration. Technically your battery is in the interior of your car and not the trunk, therefore the fumes that a battery gives off must be vented outside the car. The stuff that vents out of a battery is flammable and not good to inhale if the car is closed up.
I am interested where you got the kit and some pictures.
I plan to relocate the batteries on both of my 3rd gen T/A and Formula.
Hopefully it will give me a starting point.
You have done an Awesome job on the '84.
Stripping it down to bare is the only way to go to keep the detail of the body.
Old 12-14-2010, 07:59 PM
  #112
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
looks amazing....great work
Old 12-14-2010, 10:02 PM
  #113
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I'd honestly never seen a 82-84 bird that I thought looked good until I saw these pictures of your car
Old 12-16-2010, 05:26 PM
  #114
JeremyNYR's Avatar
Car: 1984 Trans Am
here are some pictures when I installed it back in 2005:
I bolted the tray down with 2 bolts into the rear subframe rail and also put one small bolt on the outside front corner. I have since replaced the optima redtop with another basically identical redtop. I really don't know much about batteries, but I don't think this type will cause corrosion like a standard lead acid battery.
Thank you very much BlueZee28. I really love what you've done with your car, so it's pretty cool to hear you complimenting mine. I didn't love 82-84s when I found this one, but the price was right. I've since gained a great appreciation for them and wanted to stay with a mostly original look. 15th anniversary cars are among my favorite f-bodies of all time.
Old 12-21-2010, 11:35 PM
  #115
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
I have to say it... that is one good looking car two thumbs up.
And the interior looks like its coming along nicely
How well does the 4 Gen carpet fit?
Old 12-22-2010, 07:47 AM
  #116
JeremyNYR's Avatar
Car: 1984 Trans Am
thank you! the 4th gen carpet is a 95% fit. I had to cut new holes for the front seatbelt receiver and I cut off the back part that goes behind the rear seats. Other than that, the only other thing that's kind of noticable is that the dip in the front passenger floor isn't quite the same. The 4th gen carpet doesn't dip down as low as the 3rd gen floorboard, but it isn't that noticable other than when you're putting it in. I do plan to get all new 3rd gen carpeting for it at some point though.
Old 01-16-2011, 03:07 PM
  #117
firebird123's Avatar
Car: 1991 firebird
Engine: 3.1 v6
Transmission: ?
Axle/Gears: ?
Well I spent the last two evenings working on the interior and giving it a quick wash to get the dust off. I took it for a couple little cruises around the neighborhood tonight and took some pictures in the driveway. I got lots of looks on the road and one interesting conversation. I stopped at the parts store to get amber bulbs for the front side markers, but I saw their cleaner's van outside and when I asked, he said they just closed. He then went on to say nice car and asked what year it was. I said '84 but with the exhaust going maybe he didn't hear me well and said "98?". I said no, '84 and he looked very surprised and said it looks good and sounds like it has some *****. Even though the interior isn't 100% together yet, i'm stopping at a local car show tomorrow night and I'm interested to see what kind of reactions/comments it gets. I'm kinda liking this nice looking f-body thing :driving:
my camera isn't very good in night mode. I really wish that last picture came out better. I'll probably take some more tomorrow night at the car show with a better background. I got the passenger seat, headliner and door panels in after the daylight pictures.
what kind of wing is that?
Old 01-16-2011, 07:24 PM
  #118
JeremyNYR's Avatar
Car: 1984 Trans Am
The spoiler is a reproduction made by Wings West. I believe they refer to it as a wrap-around style spoiler. It was originally available on the 1984 Firebird 500, which was basically a "special edition" created by one dealership.
Wings West also makes an almost identical one for 3rd gen Camaros.
Old 01-17-2011, 01:16 AM
  #119
Car: 1991 firebird
Engine: 3.1 v6
Transmission: ?
Axle/Gears: ?
thk big help.
Old 01-17-2011, 02:23 AM
  #120
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
daamn, i SO dig your wheels in combo with that awesome, clean platinum paintjob on such a nice 84! all thumbs up for you greetz
Old 02-04-2011, 06:01 PM
  #121
slow84ta's Avatar
Car: 84 15th Anniversary Trans Am
Engine: built 406
Axle/Gears: 3.73 10bolt
It was nice to have helped with the build at first, but I'm sad I haven't seen it yet with the new paint. Maybe this summer, it is possible that I'll be up there for the big Pittsburgh vs Buffalo drags May29th at Lucky Dog City in Erie PA..... That is of course if I can get a rear and truck and trailer by then.....
Old 02-08-2011, 02:42 AM
  #122
Guest
Guest
Posts: n/a
nice.
Old 02-08-2011, 10:57 PM
  #123
propaintball96's Avatar
That came out awesome. Love the wheels... Definately need to lower it though. Id say inch in the back, inch and a half in the front. maybe 2.
Old 02-09-2011, 08:44 AM
  #124
JeremyNYR's Avatar
Car: 1984 Trans Am
Thanks for the compliments guys. I don't get why there are so many lowering comments though. It's already lowered with an Eibach Pro Kit. Maybe another inch lower with the sportline kit would look good, but another 2 inches would put it on the ground! I still want it to be drivable too. Maybe the angle of the pictures are making it look higher because I was kneeling down to take most of them.
Old 02-09-2011, 09:58 AM
  #125
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
That car looks amazing! I agree with you lowering the car looks show room cool but it's not practical for the streets.
Old 02-09-2011, 05:28 PM
  #126
really? I have mine on sportlines and it sits much nicer...Id probably go with those. At least in the front
Old 02-09-2011, 05:42 PM
  #127
JeremyNYR's Avatar
Car: 1984 Trans Am
After looking through this thread again today, I realized that I didn't post many of my favorite pictures from this past summer after I got the bird out of my driveway and drove it around town.
This was at an awesome f-body/mustang event featuring all generations. Very fun time.
this one is with my brother in law's 81 Monte with a BBC and an awesome true dual exhaust
In my friend's driveway before that f-body/mustang event
parked next to a 5th gen at a local cruise night. The height difference is staggering!
Old 02-09-2011, 05:43 PM
  #128
JeremyNYR's Avatar
Car: 1984 Trans Am
I was bored while waiting for chinese food and couldn't help but snap a few pictures.
And finally back home enjoying a cold beer and a nice view
most of these were cell phone pictures, so please excuse the blurriness.
Old 02-09-2011, 10:34 PM
  #129
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
i think ive already said this, but man SICK BIRD!!!!....seriously amazing....lucky not to have snow
Old 02-09-2011, 10:38 PM
  #130
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
I don't know if this is a good suggestion or not, but make the clear sidemarkers tinted to match your grill deletes. Would that look better?
Old 02-10-2011, 07:52 AM
  #131
JeremyNYR's Avatar
Car: 1984 Trans Am
maks10, we have TONS of snow here in Buffalo, NY! All those pictures were from last summer. I can't wait to take it out of hibernation when it looks like that outside again!
knightmarecs, the lenses are actually smoked rather than clear. They do look kinda light in the pictures though. I guess i'd have to hit them with some VHT Niteshades to darken them up more. I might do that, especially since I plan to tint the windows this summer.
Old 02-11-2011, 01:00 AM
  #132
batsibf's Avatar
Car: 1986 Firebird
Engine: 3.4L Swap is done
Axle/Gears: Stock
Nice I have snowflakes on my '86 silver bird, and I don't care for them, but I hope mine looks as good as your dose when I'm done
Old 02-11-2011, 01:04 AM
  #133
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Damn dude that is a nice car! Love those year of firebirds
Old 02-11-2011, 08:50 PM
  #134
avilla20's Avatar
Car: 1990 rs/1986 iroc-z
Engine: Lho 3.1 v6/Lb9 5.0 v8
oh man what a kick *** bird, ive been considering buying a trans am and matching it with those rims but was unsure....now im sold!!!!great job
Old 02-11-2011, 10:32 PM
  #135
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
amazing car, great job
Old 02-11-2011, 10:57 PM
  #136
rockchalk's Avatar
Car: 92' RS
Engine: LT1 from a 94 Ram Air
Transmission: Beefed 700R4
Great car love it.....one day i'll get off my butt and post the in work pics of mine.
Old 02-12-2011, 04:46 PM
  #137
85_ZED28's Avatar
Car: '85 Z28
Wow. Excellent job!!!
Old 07-12-2011, 09:34 AM
  #138
conlinj's Avatar
car looks great man, love the wheels. What size tires do you have?
Old 07-12-2011, 09:47 AM
  #139
58mark's Avatar
this car is so beautiful I'm sitting here stunned.
Have you ever considered swapping out the taillight lenses for the GTA style?
Old 07-12-2011, 10:01 AM
  #140
84beaut's Avatar
Car: 1984 Pontiac Firebird
Engine: 4th Gen 3.4 V6
Axle/Gears: Stock
Wow. Just amazing.
Old 07-12-2011, 01:58 PM
  #141
Car: 82,83,99 T/As
Engine: 350,350,383
Early bird tails > GTA tails
Old 07-12-2011, 02:00 PM
  #142
58mark's Avatar
Well everyone is certainly entitled to their opinion
Old 07-12-2011, 03:31 PM
  #143
Car: 82,83,99 T/As
Engine: 350,350,383
Didn't mean to be snide. Just throwing in my 2 pennies.
Old 07-12-2011, 03:33 PM
  #144
58mark's Avatar
not at all. I meant it. we all have our opinions. I think it would look a little cleaner with more modern looking taillights, and you (and the owner apparently) like those. It's all good man
Old 07-13-2011, 12:05 PM
  #145
JeremyNYR's Avatar
Car: 1984 Trans Am
thanks guys. I did think about swapping in the later grid style taillights and even have a pair on a shelf, but I decided to stick with the original style. They're going to get polished and get the firebird emblem and "PONTIAC" lettering done in silver at some point. I think that'll make them look a lot better and I like the early 3rd gen/late 2nd gen feel of the car with those tail lights and the snowflake wheels.
Old 07-13-2011, 12:08 PM
  #146
58mark's Avatar
i wasn't going to say anything, but the dull, flat surface of the taillights were why I said anything at all.
You have a BEAUTFUL car, maybe the best looking 3rd gen I've ever seen, seriously, but the taillights look a little neglicted and weathered. no offense
polishing them with compound would probably make them POP
Old 07-13-2011, 06:53 PM
  #147
JeremyNYR's Avatar
Car: 1984 Trans Am
thank you very much 58mark. There's no doubt that the tail lights need attention, and at some point they will get it. If after polishing them they don't look much better, then I'll reconsider the later year taillights with some additional darkening done to them. And you wouldn't believe how good it makes me feel to have someone say I might have the best looking thirdgen they've evern seen. I can't accept it as true because I know all the little flaws mine has, but it still feels really good to hear it
Old 07-13-2011, 06:56 PM
  #148
JeremyNYR's Avatar
Car: 1984 Trans Am
I had a seperate thread about adding a magnaflow catback and getting the windows tinted, but I might as well add it to this main thread. I can't wait to have an update with the taillights redone, but it probably won't be until next summer.
Old 07-14-2011, 09:15 AM
  #149
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
wow man this is awesome!
Old 07-14-2011, 02:20 PM
  #150
Car: 82,83,99 T/As
Engine: 350,350,383
If you on taking off the gold center bird, I'm interested in it lol.
Quick Reply: My 1984 Trans Am is Finally repainted in Platinum! Lots of pics!
