End of project sell-off - Third Generation F-Body Message Boards
Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Old 03-30-2016, 08:04 PM
QwkTrip's Avatar
Peoria, IL
Everything I didn't use or don't want from my 1989 Firebird project. This is a desert car so most things are rust free. Some will cost you, some is free if you just come get it. I don't want to ship things for the most part but I may get talked into it if some things sit for a long time.
$20. Brand new HVAC selector switch. New from GM dealership.
$15. Another new HVAC selector switch from Autozone. Same style as above.
$10 each, LQ4 6.0L LSx truck coils (5 pieces remaining)
$40. Brand new upholstered sail panels (cover for rear speakers). Light grey color.
Sold. Free, alternator, 1989 2.8L.
Sold. Free, original brake master cylinder from my car, 115K miles.
Sold. Free, large box of parts from my V6 engine. Very good condition.
Sold. Free, large diesel engine piston and rod for display.
Sold. 2000 F250 Superduty brake pads. New in box.
Sold. Various U-joints new in box.
Sold. Calvan double flare tool kit.
Sold. Hawks Motorsports "Firehawk" style bolt-in roll cage. Brand new and powder coated grey.
Sold. Skulte crossmember for T56. Very rare.
Sold. New Hooker double hump trans crossmember with adjustable torque arm mount.
Sold. Torque arm from 1200 HP turbo car. No branding. Front bearing needs replaced.
Sold. Bilstein yellow front struts.
Sold. Koni red adjustable rear shocks.
Sold. Full set of Suspension Techniques lowering springs.
Sold. Full set of Hotchkis lowering springs.
Sold. Hypercoil lowering springs, rear only
Sold. Manley push rods 7.375" length, 5/16" diameter for LS style engine.
Sold. TRx V.2 cam for LS engine.
Sold. LS1 ECM bracket, new in package from GM.
Sold. LS3 valve covers.
Sold. New PowrMAF 4" MAF with LS7 card. (Rebranded Halltech)
Sold. SSBC proportioning valve, used.
Sold. SSBC proportioning valve, new.
Sold. C4 HD 13" front brakes.
Sold. Fiberglass AC delete housing with resistor card.
Sold. Coolant reservoir, new in box.
QwkTrip is offline
Old 03-30-2016, 08:45 PM
QwkTrip's Avatar
Re: End of project sell-off
All this stuff is from a fairly new LS7 crate engine with only 90 hours of run time (that's really low miles). Upgrading engine, selling things I won't need.
Buyer pays for shipping and PayPal fees, if used.
$30. LS7 pushrods, full set (16 pieces).
SOLD. Complete set of LS7 heads.
SOLD. LS7 lifters, full set (16 pieces).
SOLD. LS7 lifter trays (4 pieces). Should fit any LS engine.
SOLD. LS7 harmonic damper.
SOLD. LS7 camshaft.
SOLD. Katech LS7 oil pump
QwkTrip is offline
Old 03-31-2016, 01:46 PM
DynoDave43's Avatar
PM sent.
DynoDave43 is offline
Old 03-31-2016, 05:03 PM
QwkTrip's Avatar
DynoDave, did you look at your original switch and make sure it looks the same? I had a heck of a time finding the right switch for my '89, which is why I have extras. Everybody is carrying the wrong part. Never did find a new switch and had to go to the junkyard.
As far as I can tell, the switches below are for early 3rd gens, not the later 3rd gens. The fan will never shut off if you install in my '89.
QwkTrip is offline
Old 03-31-2016, 09:03 PM
pm sent
Wirewrestler is offline
Old 03-31-2016, 09:07 PM
igotta355z28's Avatar
pm sent
igotta355z28 is offline
Old 03-31-2016, 10:43 PM
QwkTrip's Avatar
Replied to everyone.
Wirewrestler, I can't guarantee the alternator works, that is why I am not taking money. It worked when I pulled it off my car 16 years ago and it was probably only a year old at that time. Usually grease separates after sitting a few years so the bearings may not have quality grease in them. In other words, the alternator might work and then the bearings fail on you after a few months. Worst case scenario is you get a really clean core for free that you could have rebuilt by a competent shop.
QwkTrip is offline
Old 04-01-2016, 09:36 PM
QwkTrip's Avatar
More items added.
QwkTrip is offline
Old 04-09-2016, 11:37 PM
QwkTrip's Avatar
Edit: Item removed because it sold.
QwkTrip is offline
Old 04-10-2016, 07:47 PM
bizzle88's Avatar
torque arm still available?
bizzle88 is offline
Old 04-11-2016, 12:20 AM
QwkTrip's Avatar
Yes, sir.
QwkTrip is offline
Old 04-11-2016, 02:39 AM
jclopezz's Avatar
Originally Posted by QwkTrip View Post
More items...
** Don't have picture right now. They are in back of car at speed shop at the moment. **
$12 each. Various U-joints. From left to right,
* Precision 348. (1310 to 1350 conversion)
* Spicer, stamped with numbers F1 and U71. (unknown, appears to be 1330 to 1350 (?) conversion)
* Appears to be the same as the Spicer.
$ Free. The original master cylinder from my 1989 Firebird. Probably worked just fine, I replaced it only for good measure.
$50. LS3 valve covers. Nice surface finish, very little oxidation, but some of the threads are stripped where the coil studs mount. You'll want to oversize and tap the holes.
Is the master cylinder available still? would you ship? I would obviously pay for it. Thank you in advance for your time and help
jclopezz is offline
Old 04-11-2016, 11:12 PM
QwkTrip's Avatar
Updated the list. All the free stuff is gone.
QwkTrip is offline
Old 04-12-2016, 02:31 PM
QwkTrip's Avatar
Skulte crossmember is gone. List updated.
QwkTrip is offline
Old 04-12-2016, 02:45 PM
QwkTrip's Avatar
Just so people know, the front bearing on the torque arm just screws in to the end of the rod. It is a normal service part and couldn't be easier to replace. Only reason I'm not asking twice as much money for torque arm is because I don't know the brand. You can replace the bearing with whatever style you want - poly, spherical, Del-sphere... whatever.
First person to recognize this is going to get the deal of a lifetime on an adjustable torque arm!
QwkTrip is offline
Old 04-12-2016, 03:01 PM
QwkTrp - where are you located? Trying to figure out shipping.
joshy1410 is offline
Old 04-12-2016, 03:03 PM
Nwm, Peoria... helps to read.
Old 04-12-2016, 03:08 PM
Pm sent.
Old 04-15-2016, 07:42 AM
QwkTrip's Avatar
Bearings are about $10.
QwkTrip is offline
Old 04-17-2016, 01:12 PM
DynoDave43's Avatar
Another PM sent.
Old 04-26-2016, 07:14 AM
QwkTrip's Avatar
Brake pads sold.
QwkTrip is offline
Old 04-26-2016, 07:50 AM
SLAB's Avatar
PM sent
SLAB is offline
Old 04-26-2016, 12:15 PM
QwkTrip's Avatar
I never got a PM from you.
QwkTrip is offline
Old 04-26-2016, 12:56 PM
SLAB's Avatar
Hmm. Probably because I'm new.. Idk what the rules are for PMs
SLAB is offline
Old 04-26-2016, 06:40 PM
QwkTrip's Avatar
The Great QwkTrip-O will now amaze the young and old, women and children,
and men from all walks of life, with his amazing mind reading skills....
--> Lowering springs. You're thinking about the lowering springs.
QwkTrip is offline
Old 04-26-2016, 06:55 PM
SLAB's Avatar
Amazing! How does he do it??
I take it you got my PM..
SLAB is offline
Old 04-26-2016, 09:24 PM
QwkTrip's Avatar
Nope, I just guessed. You're going to have to talk to me if you want to do this. I need an e-mail, phone number, or I can PM at LS1tech.com if you have an account over there.
QwkTrip is offline
Old 05-01-2016, 03:00 PM
QwkTrip's Avatar
Springs are not sold. Anybody still can pick these up.
QwkTrip is offline
Old 05-09-2016, 05:06 PM
QwkTrip's Avatar
Added picture of the sail panel covers.
QwkTrip is offline
Old 05-13-2016, 10:04 PM
QwkTrip's Avatar
$30. New in box coolant reservoir, 88-92 style (purchased from Ecklers). I had trouble getting the cap to screw on this one because hole is a bit large.
QwkTrip is offline
Old 05-14-2016, 01:01 PM
ThirdGenKen's Avatar
Springs still for sale?
ThirdGenKen is offline
Old 05-14-2016, 01:28 PM
QwkTrip's Avatar
Yes, I keep this thread up to date.
QwkTrip is offline
Old 05-15-2016, 03:08 PM
How much of a drop are the springs?
Old 05-15-2016, 03:54 PM
QwkTrip's Avatar
1" or something like that. Moderate and sensible amount.
QwkTrip is offline
Old 06-21-2016, 05:44 PM
QwkTrip's Avatar
Everything you see is still for sale. These lowering springs are a bargain and somebody could be rollin' around in style for cheap.
QwkTrip is offline
Old 08-27-2016, 08:43 PM
QwkTrip's Avatar
Adding an item
Manley push rods, 7.375" length, 5/16" diameter for LS style engine
Full set of 16, used. Did a cam swap and needed shorter push rods.
**sold***
QwkTrip is offline
Old 09-03-2016, 10:42 AM
QwkTrip's Avatar
** sold **
Just pulled this cam from my engine. Appears to be a Thunder Racing TRx V.2, As usual with performance cams this is a 3 bolt design
Comp Cams lobe numbers
3731R / 3734R HR 110+2
XTreme Energy XE-R LS1
Duration at 0.05
INTAKE
Duration: 242
Lift: 0.610
Valve Open: 13 BTDC
Valve Close: 49 ABDC
EXHAUST
Duration: 248
Lift: 0.615
Valve Open: 56 BBDC
Valve Close: 12 ATDC
QwkTrip is offline
Old 10-01-2016, 12:02 AM
QwkTrip's Avatar
I still have almost everything. Surprised some of this stuff isn't selling, especially the lowering springs. I figured those things would be the first to go!
QwkTrip is offline
Old 10-06-2016, 07:50 PM
QwkTrip's Avatar
Push rods are sold.
QwkTrip is offline
Old 10-15-2016, 12:18 AM
QwkTrip's Avatar
Camshaft is sold.
QwkTrip is offline
Old 02-15-2017, 09:01 PM
QwkTrip's Avatar
The huge piston and connecting rod is gone. I was finally able to give that away to somebody that now has a cool item to decorate their shop.
QwkTrip is offline
Old 02-16-2017, 04:35 AM
  #42
you still have the springs? located in dekalb, il
Cheerio is offline
Old 02-16-2017, 05:38 PM
  #43
QwkTrip's Avatar
I have everything shown. I keep this thread updated.
QwkTrip is offline
Old 02-18-2017, 06:01 PM
  #44
QwkTrip's Avatar
Torque arm and lowering springs are gone.
QwkTrip is offline
Old 09-09-2017, 01:20 AM
  #45
QwkTrip's Avatar
I didn't expect this stuff to fly off the shelf but honestly surprised that these particular items are still here.
* speaker sail panels
* AC delete box
* Coolant reservoir
* Cal-Van 163 double flare tool kit
QwkTrip is offline
Old 09-09-2017, 02:18 AM
  #46
Robbie_S's Avatar
How does the plastic on the coolant tank look?
Robbie_S is offline
Old 09-09-2017, 12:09 PM
  #47
QwkTrip's Avatar
It is brand new. Info is in post #1 and I updated the picture link for you. (I don't use Photobucket any more.)
QwkTrip is offline
Old 09-09-2017, 12:32 PM
  #48
QwkTrip's Avatar
Added a couple LSx swap trans crossmembers.
These are the only double hump cross-members on the market and both are for sale here. Hooker has a torque arm mount. Hawks does not have a torque arm mount but offers more space for exhaust.
See Post #2 for pictures and info.
QwkTrip is offline
Old 09-19-2017, 10:45 PM
  #49
QwkTrip's Avatar
** sold **
Added a set of Bilstein yellow front struts.
$100. Bilstein "yellow" front struts. Many years old but only about 1000 miles. No leaks, excellent condition.
QwkTrip is offline
Old 11-06-2017, 06:43 PM
  #50
QwkTrip's Avatar
Bilstein struts sold. Everything in posts #1 and #2 still for sale.
* AC delete with fan and resistor board. Aftermarket fiberglass.
* LS1 PCM mounting tray
* Moroso extra long transmission housing dowel pins
* Upholstered sail panels (cover for rear speakers). Light grey color.
* LS3 valve covers.
* Coolant reservoir, 88-92 style
* Hooker trans crossmember
* Hawks T56 trans crossmember
* HVAC selector switch
* LQ4 6.0L LSx truck coils
QwkTrip is offline
RPM WOT L 98
07-06-2017 01:05 AM
ASE doc
07-20-2016 03:22 PM
Paulie84vert
03-29-2016 04:14 PM
LC2 TECH
03-26-2016 10:32 PM
mballejos87
03-26-2016 09:26 AM
Advertising
Featured Sponsors
Vendor Directory
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
