Sign Petition To Get Pure Gas In Chicago Area
Transmission: World Class T-5
Axle/Gears: BW 3.45
There is nowhere in the Chicago area which non-ethanol gas is available for our cars. Sign the petition below.
http://www.fuel-testers.com/fuel_cho...taA-FqUFMELZ9o
Axle/Gears: BW 3.45
Re: Sign Petition To Get Pure Gas In Chicago Area
The bigger concern is long term usage and storage.
https://www.hagerty.com/articles-videos/Articles/2009/08/12/Ethanol-Demonic-or-Devine
https://www.hemmings.com/blog/2012/11/14/tech-101-ethanol-in-gasoline-and-its-effects-on-collector-cars/
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would agree on the running, but ethanol is very hard on the rubber parts in the fuel system during long term storage. It essentially destroyed my friend chainsaw from sitting in the tank. He won't make that mistake again.
It's really not good for the steel parts either
Axle/Gears: BW 3.45
Anyways, I'd like to have the choice. I'd DEFINITELY go with pure gas for my old cars.
But this will be a losing battle. The bottom of that form says this:
"Sadly, EPA (Environmental Protection Agency) abandoned its true mission and became both the Environmental Politics Agency and the Ethanol Promotion Agency..."Quote of Charles T. Drevna, President of NPRA, the National Petrochemical & Refiners Association, 10/23/2010
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
We found that more horsepower was made with pure gasoline than with E10. This was during back to back engine dyno testing on Vortec style sealed circle track engines. The comparison was made between Shell's premium (92 octane and no ethanol) and Sunoco's Ultra 94 (which in these parts has 10% ethanol). Resistance to detonation wasn't an issue as these are relatively low compression pressure engines at about 9.5:1.
Horsepower was up an average of 5%.
Sadly now, all fuel sold in this country has to have a minimum 10% ethanol.
That said, for the average hotrodder, the impact is minimal and any well designed fuel system will have resistance to the effects of the additive.
Good luck with the petition.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
I have non-ethanol fuel in Peoria. How come you don't in Chicago? Maybe stop voting the liberals into positions of power and it won't be like that.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Chicago is requiring something different than the rest of the state. I don't think you were catching on to that.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
It turns to like a powder when it evaporates which causes problems on my seasonal toys (boats, jetskis, sleds).
-- Joe
-- Joe
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 Let's Go Brandon
Ethanol is horrible, and the ONLY reason for E10 is to subsidize the agricultural industry (corn).
It reduces fuel economy, and in cars that are stored seasonally, it absorbes moisture and creates a nasty varnish that clogs fuel systems. It's hell for carburetors. It does absolutely NOTHING to reduce pollution...
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Wait a minute.... You mean to tell me that elected politicians establish policy?
Car: '84 Z
Engine: L69
The ethanol law and needs vs requirements are relatively complex. Apparently the chicken or the egg metaphor can apply to the product.
Burning alcohol can be good, but as noted it causes problems on some fuel systems and most carbs. Boats, pwc, snowmobiles, etc.
-- Joe
I don't think ethanol in gasoline has much do do with subsidizing the corn industry, but there is some evidence that it reduces hydrocarbons and that was enough for the EPA to push for it.
-- Joe
-- Joe
Sure it does, a higher concentration of ethanol produces less ozone-forming compounds. Ethanol fuels produce less carbon and hydrocarbon emissions.
E85 for performance applications can have lots of added benefits.
But as previously stated, ethanol can wreck havoc on some fuel systems. I have to rebuild carbs on sleds/jetskis/boats a lot, stuff that has a lot of downtime throughout the year.
-- Joe
-- Joe
-- Joe
-- Joe
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
Signed Chazman. While I’m on the fence about it (use it and don’t mind for daily’s and such) I do believe it effects older models and equipment not suited for it and the consumer should have a choice as well as a voice in the matter. Come to think of it, if my brother still lived in IL and not IA he’d be the spokesperson for the matter. He’s a smart educated dude, and even his response for most issues is “it’s probably crappy fuel”
MikeCpa
01-09-2017 03:26 PM
SKELITOR117
04-08-2012 03:11 PM
Ward
05-31-2001 12:12 PM
