Northern California Discussion board for Northern and Central California.
finally lowerd the vert
Old 09-30-2008, 10:46 PM
SMOKIN Z's Avatar
Car: 1991 z28 vert/91 rs vert/85 TA vert
Engine: stock tpi 305/tbi 305/tpi 305
Transmission: 700r4/ 5 speed
Axle/Gears: 4th gen rear in progress/stock
finally got 1 inch lowering springs for the vert. i think they are perfect. the ride is still smooth, not like the rice burners hopping all over the place.
so what you guys think? here's some before and after pics
Attached Thumbnails finally lowerd the vert-1991-camaro-z28-006.jpg   finally lowerd the vert-1991-camaro-z28-007.jpg
Old 09-30-2008, 10:48 PM
SMOKIN Z's Avatar
Re: finally lowerd the vert
after
Attached Thumbnails finally lowerd the vert-dsc04809.jpg   finally lowerd the vert-dsc04812.jpg   finally lowerd the vert-dsc04814.jpg
Old 09-30-2008, 10:50 PM
SMOKIN Z's Avatar
a few more
Attached Thumbnails finally lowerd the vert-dsc04817.jpg   finally lowerd the vert-dsc04820.jpg   finally lowerd the vert-dsc04821.jpg
Old 09-30-2008, 11:01 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Looks good
I need to do that to my vert. What springs do you use?
Old 09-30-2008, 11:31 PM
SMOKIN Z's Avatar
thanks. i went with the Hotchkis springs. now i have to take it to the alignment shop.
Old 10-01-2008, 01:14 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
That looks sweet man! That is the perfect stance for your car. When are you going to cruise man??
Old 10-01-2008, 11:08 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Looks mean!
Old 10-01-2008, 05:14 PM
SMOKIN Z's Avatar
thanks, as far as cruising not till spring when i get the car painted, and a few other things taken care of.
Old 10-01-2008, 06:00 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Sounds good man. if you need a hand let me know. Im down for anything
Old 10-01-2008, 06:09 PM
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
nice
Old 10-01-2008, 10:59 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
looks great.
Old 10-01-2008, 11:08 PM
Mr. IROC-Z's Avatar
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Welcome to the club! Looks nice.
Old 10-08-2008, 08:53 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Looks good man. Later.
Old 10-08-2008, 10:25 PM
SMOKIN Z's Avatar
thanks guy's for all the comments.
Old 10-09-2008, 12:42 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I also used the Hotchkis set but mine dosn't look anywhere near as down & mean as yours. Any clearance issues with the front fenderwells??? I'm having to add a set of 1/8" spacers to the front 88-89 IROC 16" wheels. Nitro
Old 10-09-2008, 01:23 AM
SMOKIN Z's Avatar
I've read that convertibles are heavier then a hard top, or t-top car,so that could explain why mine sits lower. the front wheels don't rub at all, i haven't reinstalled the fender liner(think that's what it's called) so i dont know if it will rub or not with them on.
Old 10-18-2008, 03:17 PM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Damn that looks good!
Old 10-30-2008, 03:03 PM
NoCal91Convert's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 Speed
What wheels and tires do you have on there? I have mine lowered, but the ride is totally hard. Were the springs designed for a vert? How much and where did you get them?
Love the look, I wanted to stay with the stock 91 wheels, but I think 18's or 20's lowered will give a tucked look but still provide some clearance and comfort. This is a difficult formula to get right so any of your information will help lots.
Old 10-30-2008, 03:54 PM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
those rims and tires are great looking. What kind are they, they almost look like saleen rims.
Old 10-30-2008, 04:12 PM
Axle/Gears: Stock
Guys, who is the question for. Later.
Old 10-30-2008, 10:03 PM
Doc_G's Avatar
Car: 87 Trans Am
Sorry, I was asking smokin z about his rim/tire combo.
Old 10-31-2008, 12:51 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
looks good.......I so want a vert
Old 10-31-2008, 02:58 PM
Both Mr Iroc and Smoking look great. I'd be happy to hear about rims and tires from either. Smoking mentioned his nice ride, that is also of great interest to me and specifics there would also help (springs expresssly for convertibles or not, shocks, etc.)
Old 11-03-2008, 07:29 PM
SMOKIN Z's Avatar
I'm using the stock corvette C6 wheels, 18x8.5 front, 19x10 rear. tires are 265/30/18 and 285/30/19. I bought the spring from summit racing. They are the one inch lowering spring for Hotchkis. I knew i couldn't go any lower then 1 inch because of the rear fender wells being flat at the top. here is a link for the springs.http://store.summitracing.com/partde...514+4294859383
Old 11-04-2008, 10:36 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
What size rear foot print did you get? Do they rub anywhere? Is that a stock 3rd gen rear?
Old 11-07-2008, 10:12 AM
Mr. IROC-Z's Avatar
I'm running 18x8 fronts and 18x11 rears. Tires are 255/45/18 ans 295/40/18.
I forgot the company name of the springs, but I custom ordered them with specific ring weight, and cut them myself. It's been such a long time, but I think the fronts are 180lbs rated and the rear 160.
Tommy
Old 11-07-2008, 02:51 PM
Mr.Iroc, how would rate your ride compared to stock.
Old 11-08-2008, 02:50 AM
fryer1979's Avatar
Engine: 350; none
Smokin Z, and Mr. Iroc, those large width rear wheels, did you have any clearance issues with them? I would like to have 17" or 18" by 10" rims on the rear of my '84 Z28, and would like to know of any fitment issues either of the two of you had. Any special backspacing or spacers needed with a stock width rear-end? I really don't want tire sticking out from the fenders.
Old 04-08-2013, 10:56 PM
DrNBody's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: LB9 305 TPI
What shocks did you pair up the Hotchkis coils with? Look awesome
Old 04-09-2013, 10:50 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
i'd be suprised if you get a response back. Smokin Z hasn't posted on this site in a long time it seems.
Old 04-09-2013, 11:42 AM
DrNBody's Avatar
Engine: LB9 305 TPI
Bummer...
Just reading things and thinking about future mods
Old 06-10-2014, 11:16 AM
Unklebrownkey's Avatar
Car: 91 Camaro Rs Convertible
Engine: 305 TBI
Transmission: 700R4 Auto
Axle/Gears: Stock
your vert is looking nice, we should cruise sometime i'm from stockton as well.
@SmokinZ
Heres a pic of my vert lowered on 22" Irocs and on 16" Stocks.
Old 06-10-2014, 02:47 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Please take those 22s off that third gen!!!! Your killing that car!!!!
okfoz
10-13-2015 02:19 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
Aaronv808
Members Firebirds
09-30-2015 12:55 PM
HoosierinWA
Members Camaros
09-29-2015 12:43 PM
tcarlos13
Interior Parts Wanted
09-28-2015 06:31 PM
Quick Reply: finally lowerd the vert
