FS: Stock driveline and suspension and more
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I have a lot of parts from my 89 Camaro IROC-Z for sale. I have pictures of everything except the rear and suspension because they are still on the car. Feel free to make offers, please.
TPI intake manifold and associated parts:
-Throttle body
-Adjustable fuel pressure regulator
-Fuel lines
-Water Neck and thermostat
3" Flowtech exhaust cutout
19lb/hr injectors
Various climate control parts including condenser, evaporator assembly with switches, wiring, blower motor, resistor, controls (All climate control has been removed from the car)
Most cruise control related items
Stock crankshaft, pistons, rods (104k miles- L98 motor)
AutoMeter Phantom Air/Fuel indicator gauge, 2 1/16"- $25
Starter- $10
Water pump- $10
Instrument cluster trim piece
Valve covers- good shape- $25
Stock lifter guide plates
Stock rocker arms
Two (2) Accel coils
AIR Pump and hoses
Stock 153-tooth flexplate
OEM Fan switch and thermostat- never used
Complete PBR disc brake 9-bolt rear end- should be 2.77 gearing- make offer
Stock driveshaft (700R4)
All stock suspension pieces (torque arm, sway bars, control arms, springs, shocks, struts, panhard rod)
Parts located in Palos Hills, IL
Remember, feel free to make offers. Most of this will likely be tossed soon. Thanks!
-Throttle body
-Fuel lines
19lb/hr injectors
Starter- $10
Water pump- $10
Stock rocker arms
Two (2) Accel coils
AIR Pump and hoses
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: FS: Stock driveline and suspension and more
hey andy, if you could PM me a price on the adjustable fuel pressure regulator and the 9 bolt i will pass them both on to a buddy of mine
Car: 1989 IROC-Z
Engine: 383 stroker
No, I already sold my electric power plate. This is just the dump.
Car: 1984 Z28
andy give me a call when u get a chance....thanks
Car: 1989 IROC-Z
Engine: 383 stroker
TPI setup, injectors, coils sold.
are you gonna dump the rear end? i bent the right side axle shaft. dont ask how but it just is. it could be due to my suspension but what the hell. im the only guy on air ride with a camaro in the area. so any info would be awesome.
1 Post
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
still got the crank and rods? how Much?
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
consider the water pump sold, p m me please. thank you
Car: 1989 IROC-Z
Engine: 383 stroker
Still looking to get this rear outta my way...
LT1Formula
11-16-2015 01:13 PM
Genopsyde
10-07-2015 08:35 PM
