89 TTA build thread
89 TTA build thread
Well I couldnt find anywhere else to put this. So the car is here in Indiana Ill put it here. Im doing some of the work on this car. But its not mine. Its going to be an awesome build so I wanted to let everyone enjoy it sense hes not a TGO member. Here are a few pics so far. A little background on the car is it was a 58,000 mile mostly original car with some minor bolt-ons and a 12 bolt till recently till the owner decided to tear it down for a major overhaul.
This is the car when I first started. Every bit of the suspension and drive train was out of the car.
This is after I installed the custom Spohn tubular k-member and spohn control arms.
Here it is after I installed the Spohn coilover kit, powder coated stock spindles and caster camber kit.
Here are the Aerospace brakes installed as well.
Re: 89 TTA build thread
And here it is after we installed one of the Weld Magnums to check brake clearance.
I dont know much about the engine/transmission combo yet sense it was built by another turbo buick enthusiast but here are a few pics.
Ill post more build pics as they come. This week Ill be installing the Nasty performance sumped fuel tank, plumb the fuel system and install the rebuilt 12 bolt rear end. More to come soon. Later.
that looks like its going to be a fun car, rather see the GTA style wheels on it myself but its not my money.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Too much race for me.
Kinda ruins what the car is best at, doing everything well.
Still it looks nice.
Shoot me some engine specs so I can compare some notes with mine.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Nice...one of the best Fbodies every built.
Sucks he's taking the stock GTA rims off....that completes the look IMO.
Its keeping the GTA wheels. The magnums are just for the track. We dont have any road courses or auto cross stuff around here but we have 4 drag strips within 2-3 hours so..... Here are some new pics. Ill try to dig up some motor specs for you Jeremy.
As a Buick GN owner... I already have a soft spot for TTA's. I WILL have one at some point. This one is awesomely clean. I know the guy that built the engine. He is top notch. I'm sure the car is going to go as much as it looks like it will go.
Again... my mouth is watering..... good job!
Yeah that thing is gonna HAUL! Lee is a really cool guy. The motor is amazingly clean. He dont a great job on the build. We are hopeing the Nasty Performance sumped fuel tank somes in tomorrow so we can get the rear end installed.
Someone at GM had to really work hard to make those tanks so difficult to remove and replace.
Good luck. I guess a lift would make things much easier...
Removing and installing a fuel tank on a 3rd gen f-body.... aren't they a GEM...... I'd rather sandpaper the butthole of an alligator in a phone booth!
Putting the tank is shouldnt be too bad with the rear end out and having it up on the lift. We will see though lol.
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Is the car lower that stock height with all the new front end components?
If so, be careful with the Art Carr pan, I have a few "light" scrapes on mine and I'm all stock.
Beautiful car I've been following the thread over on the turbo buick board. The car should be a blast too drive its setup very similar to mine suspension and engine.
Car: 92 Formula 350
Transmission: TH700R4
Axle/Gears: 3.23 posi
Sweet build! That engine looks beastly, and everything else looks really nice
Great job!
Great job!
Got the Nasty Performance fabricated fuel tank today. Had a few setbacks. The engine had a grand national style oil filter mount so I had to transfer the TTA oil filter relocation on there cause the filter was hitting the k-member. We got that all taken care of then tried to mach up the tank and found out that the straps were too short. So we have to figure something out with that. Here are a few pics of the tank.
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
That is an Awesome build man!! No was is that too much if you ask me. All of the original sheetmetal is untouched and looks very steetable. Looks Great!
BTW any close up or detailed pictures of the coilovers?
Got the tank installed today. Had to flatten the straps out completely and rebend them to fit the tank. They were too short for the new tank. I fit them to the tank, put foam on the body and the straps and made spacers and installed new bolts. I wired up a new relay and fuel sending unit pigtail and wired up the fuel level sender. Then Lee came over and we worked on locating all the wiring and vacuum lines. That was all for today. Hopefully more to come tomorrow.
1 Post
Wow,
Is that car that clean or was work put in to the underneath?
If not it looks super clean.
gonna make me jealous lol
No work on the underside other than normal cleaning. The car only has 58,000 miles and Im sure all its life its lived in a garage. The interior looks like brand new also. Ill get pics of the interior when its off the lift.
We made some more progress on the TTA yesterday and today. Shane welded up the fuel pump mounting bungs to the tank and mounted the fuel tank. Also ran the -12 line from the tank to the pump.
We also got the QA1 coilovers installed today along with the Spohn torque arm and Dynotech aluminum driveshaft. Then hung the built 3.73 geared 12 bolt with Aerospace brakes and last but not least the Spohn adjustable drag bar.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looking sharp you finish this yet buddy? feel free to stop up and help wrench on mine shortly Only got like 2 weeks to go before track time.
Car: 1989 Turbo Trans Am
Engine: 3.8 SFI Turbo
Transmission: 200-4r
Axle/Gears: stock
I can't wait for some pictures of this car completed!!! It must be done by now, right? Any times yet????
This car looks awsome, great project!
Hey fellas. Sorry I haven't made an update in a while. Things got really busy at the shop and the progress was slow going. Sense the last update we have finished the rear brake lines, routed the -10 feed and -8 return fuel line, installed the new externally regulated driver side fuel rail and today the new tires were mounted on the wheels. Ill post pics as soon as possible.
Axle/Gears: stock
We seriously need an update. Is it completed? Pictures please!!!!!!
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
god I want a TTA, and I want a higher mileage one to so I wont feel bad about modding it....any updates?
86CamaroDan
09-29-2015 10:08 PM
