What are your goals for the 2017 racing season? - Page 3 - Third Generation F-Body Message Boards
Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Thread Tools Search this Thread
Old 02-06-2017, 07:09 AM   #101
Car: 1987 IROC Z
Engine: OLD SCHOOL SB 383 stroker
Transmission: TH 350
Axle/Gears: F9 3.90 gears 35 spline
Re: What are your goals for the 2017 racing season?
what started as a small proyect to remove some front weight to start chasing this year goals, we ended up doing a full paint job changing from red to blue .
remove front bumper bar about 30 lbs
new bumper bar 2.5 lbs
new look for 2017
and after finished on friday night we went saturday to the Import VS Domestic bracket race at Autoclub Dragway in Fontana Ca for some T&T
First time back on the track since Octuber last year when we raced at the ET Finals in las Vegas .
we went out first round with .002 RED
but we got close to one of our goals
here is the ticket
VAGOGTA is offline   Reply With Quote
Old 02-06-2017, 07:34 AM   #102
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 370" ls
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
wow looking great my man!
mw66nova is offline   Reply With Quote
Old 02-06-2017, 10:11 AM   #103
Very nice. Vagota, do you remember the back spacing on your rear wheels?
Tarheel49 is offline   Reply With Quote
Old 02-06-2017, 08:44 PM   #104
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
My goal is to run a 10 second pass. Last weekend it ran a 11.2 on motor, but it had some issues that I believe kept it from running to it's full potential.
khulsebus is offline   Reply With Quote
Old 02-08-2017, 11:48 AM   #105
Car: 1987 IROC Z
Quote:
the back spacing is 5.5" and with 28X10.5 MT tires I didn't modify anything on the car they fit perfect
Old 03-16-2017, 10:17 AM   #106
84-Z28-Canada's Avatar
Car: 1984 Chevrolet Camaro z28
Engine: 383 sbc
Axle/Gears: Stock...this is next
Goals for the 2017 season... Figure out how I lost ET last season, and really bring the car around to it's full potential. Build as it stands:
84 Camaro Z28, full stock suspension, interior
383ci Small block, Edelbrock Performer RPM heads, intake, Holley 780 SA
10.75:1, running 91
Lunati Cam, .510 lift (can't remember duration, lsa etc.)
early 700r4 with 2400 stall
10 bolt rear, 3.23 open
So two seasons ago I ran a 14.55 at 101mph. Last year, I couldn't even get past 14.75, but still getting 101, 102 mph. I changed the tires and the carb (was an Eddy 750 AVS), so I have to figure out where I lost there. Bought a 10 bolt with a posi and 3.73 gears, so hoping that makes a fair difference. I've been told that my engine build is capable of 12s, so now it's just getting it to the ground. Always open to suggestions!
84-Z28-Canada is offline   Reply With Quote
Old 03-17-2017, 07:57 AM   #107
Wolfster14's Avatar
Car: 1990 , camaro
Engine: 496 bb
Transmission: power glide
Axle/Gears: 4.56
Did your 60 ft s fall off? what about your 1/8 mile speed and Time ?
Wolfster14 is offline   Reply With Quote
Old 03-17-2017, 08:50 AM   #108
mw66nova's Avatar
Engine: 370" ls
i'd be interested in comparing weather data as well.
Old 03-17-2017, 09:35 AM   #109
Engine: 383 sbc
I'll post time slips later on, but my 60 ft went up and my 1/8 mile ET went up, but I was still able to hit some decent (100+ mph) in the 1/4. The throttle response is solid on the car, and I think I've got the carb fairly dialed. I think it's just a tire/traction issue. The previous year I used Mickey Thompson Sportsmans (still a street tire, not a drag radial) and this year I used Pacesetters. I switched because the pacesetters were wider (255 instead of the 235 MTs I had on) both are a 26" tire though, so I don't think I was shrinking my gearing by going with too tall a tire. At the end of the day I know it's hard to judge any of this without a posi or decent rear suspension set up, because I'm just so inconsistent. As mentioned above though, I'll be swapping to a 3.73 Posi 10 bolt before the season, and I have access to a set of DOT bias ply slicks that I'm going to try out.
As for the weather, I'll have to start taking better notes, but if memory serves the 14.55 came on a warmer day (sunny, low wind, 25*c) and the 14.75 and higher was actually on a cooler day, overcast etc which you'd think would be better for air density, but not for track temp I guess. Again, it's all guess work until I get a set up that can power and traction together
Old 03-17-2017, 01:11 PM   #110
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Turn the boost up to 18 PSI and see if my 10 bolt holds together.
zacharyhorn is offline   Reply With Quote
Old 03-19-2017, 06:11 PM   #111
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
Make a few test and tune night passes. My car is practically stock but I am really curious to see what difference my full hooker exhaust (headers, y-pipe and muffler) as well as my new rebuilt transmission will make.
Maybe I can get into the high 14s?
Vinscully50 is offline   Reply With Quote
Old 03-19-2017, 06:13 PM   #112
Engine: LB9 305 TPI
new look for 2017
here is the ticket
Your Camaro looks amazing in blue. That is a damn good looking car.
Old 04-03-2017, 02:58 PM   #113
Car: 1987 IROC Z
The first goal of the 2017 season has been accomplished and was sooner than we expected and far beyond our expectations
Our goal was to get to 10.40s we did it on our 3rd time out , right off the trailer first run we got 10.501 and on the second run was 10.428 as the track got better car started to get better 60 fts and we hit 10.393 and a few 38s and the best run was 10.378 @129 mph with 1.362 60 fts
Next we are going to try E85 and see if we can get same results or better
Here is a pic of the car and the ticket
Old 04-19-2017, 02:24 PM   #114
Fastbird's Avatar
Car: 1991 Formula
Engine: 406
Transmission: TH350
Axle/Gears: 4.56
Trying to get the car to the track this year and see what my mods of the past two years are worth.
Last time out in 2015 it ran 11.16 @ 122 with a weight close to 3600 lbs.
I threw the kitchen sink at weight reduction and we'll see where it ends up. I am hoping around 3100-3200 lbs.
Fastbird is offline   Reply With Quote
Old 04-23-2017, 08:36 PM   #115
My goal is to run a 13.99 or quicker with my 92 firebird. Has a 355 with some world products heads, flat top pistons, 280 duration cam, torker ll intake, demon 625 carb, 3000 stall converter and 373 gears with a limited slip. Needs drag radials bad.
1992Firebird355 is offline   Reply With Quote
Old 05-27-2017, 09:22 PM   #116
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Have everything set up and ready to go for drag week. Looking not at a trailer this week and still waiting on my transmission.
ziggy89 is offline   Reply With Quote
Old 05-27-2017, 09:53 PM   #117
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: SBC 385, Dart heads, 11.1:1
Transmission: Hughes TH350 Trans Brk.PTC5KStall
Axle/Gears: 8.8" Swap In Progress
Quote:
Originally Posted by fasteddi View Post
Well my goals last year didn't happen. A lot of family problems and I lost my mom to stage 4 lung cancer. Sad year. Shattered a piston early season as well. Rough year to race.
I did manage to run the car a few times. A [email protected] as a best.
2017 goals.
To have a 10.99 or under pass and/or trap 125mph.
Race all 12 points races at Milan in sportsman(and/or pro class).
Top 15 in sportsman. (Dependent on how it runs out of the gate I may race pro class instead. The car does have a new 650hp rated hughes Trans brake tranny, ptc 5k stall, 2 step Rev limiter, 6 pt cage and could be competitive and would be legal. If it runs 11.20 or under easily (10-12psi of boost) then I will not slow it down or sand bag sportsman class. I don't agree with people who build 10 second cars and sandbag so badly that they let off and peddle way before the 1000ft each pass in spt).
Have the car hold together and just have a fun season.
Well I finally gave up on running V6s. For the past five almost 6 years I lived for those turbo 6s. I had a lot of great experiences and really did put the engine to the test. But I finally moved to a V8.
After racing it for the first time two weekends ago I feel very confident with this engine and car. I feel it's a very competitive consistent Sportsman class car. Although I only made three runs with it it only moved a little under 2. And once I got a good feel at the tree I made a .039 and a .040 reaction time back to back.
the other week when I raced it I really felt I could have went many rounds with it but I had a slight problem and I had to Pedal the car on my first round elimination. I completely destroyed the guy I was racing at the tree. But considering earlier that day one of my very good friends wrecked his car because his 12 bolt rear end locked up at the finish line I was a little hesitant. And I just did a V8 engine swap a week before I raced it so I was still working out all the little imperfections. Next Sunday I hope to make up for that weekend.
The one bad thing is the V8 is definitely a lot slower than the V6 was so I'm not at the bottom of my et cut like I used to be so now I do get Chase down a little bit. It ran a 12.159 and a 12.172 and a run completion 12.165.
So my new goals are to finish in the top 10 at Milan.
Although it seems like a very high goal I believe I finally have a car that can consistently run the same time over and over again. I fought that with a turbo car so many years. That turbo Camaro would run a 11.71 pass then a 11.85 the next pass and then and 11.50 to the next. it was a terrible bracket car but I will say it was fun.
fasteddi is offline   Reply With Quote
Old 05-28-2017, 08:54 PM   #118
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's one of the things I've always said about the turbo cars. That can be extremely fast. Look at a twin turbo 6L. A car like that could run an 8 second pass then drive home. In a bracket race however, turbos do not do very well because of inconsistency. In a heads up race, sure, dump the boost into the engine and run it out the top end but bracket racing is a lot different.
Turbos are relatively inexpensive HP and the power level can be changed by playing with wastegate settings but I'd rather have a big blower sticking out of my hood screaming HP. Downside to big blower cars is that you're not going to easily make an 8 second pass then drive home unless you swap the pulleys to run it in a deep underdrive to reduce the boost.
AlkyIROC is offline   Reply With Quote
Old 05-29-2017, 11:19 AM   #119
skinny z's Avatar
Car: 86 Sport Coupe
Quote:
Not too far removed from my earlier builds.
Went 12.6 @ 107 (12.4 @ 109 corrected). 3650 lbs.
Yes, you'll definitely need tires. I'd gone 1.7 60' but that's long gone now that the ET Streets have lost their stickiness. New radials on order for later this year.
skinny z is offline   Reply With Quote
Old 05-30-2017, 05:45 AM   #120
fasteddi's Avatar
Car: 1991 Camaro RS
I couldn't agree more. I have had some days where my car was pretty deadly consistent but those days were few and far between. It could be different if I would have gotten to build up 5psi and leave off the trans brake. But since I was a slow 11 second car the class I was in wouldn't allow it.
Old 09-13-2017, 08:00 AM   #121
Wolfster14's Avatar
Car: 1990 , camaro
Engine: 496 bb
Axle/Gears: 4.56
Quote:
Originally Posted by Wolfster14 View Post
Looking to drop from the lows 6 s to the high 5 s in the 1/8.
Swapped out a set of heavy cast iron 049 for a used set of Brodix RR ovals. They had some nice port-work done to them so I had my victor manifold matched.
Hoping between the weight savings and the better flowing heads it will make it happen.
Time will tell.
Finally got her in the 5s last weekend. Most of the passes where 5.96 at 115mph.
but did have one 5.95, not to bad for a 496 with oval ports.
Old 09-13-2017, 09:58 AM   #122
skinny z's Avatar
Car: 86 Sport Coupe
While it's nice to see the success of others, some us (namely yours truly) didn't get the chance to race at all this year. The work schedule overlapped the only test and tune day. It kind of sucks that since the local track was taken over by the NHRA (from IHRA) they also dropped the mid-summer mid-week test day. Strictly Fridays now and I'm out of town every Friday.
Made some improvements in the engine too (ported heads, bigger cam) as well as the transmission (Gearstar Level 4 equivalent and another 500 additional stall) but never got the chance to test.
Maybe next year I'll be able to post in "What are your goals for the 2018 racing season?"
Old 09-13-2017, 12:26 PM   #123
fasteddi's Avatar
Car: 1991 Camaro RS
Very nice. I see your plate says ibew.... electrician? I'm a UA local 50 member I have alot of friends and such that work with ibew local 8. Northwest Ohio. Se. Mich.
Old 09-14-2017, 01:29 PM   #124
Wolfster14's Avatar
Car: 1990 , camaro
Engine: 496 bb
Axle/Gears: 4.56
Yes Sir, I am currently a Business Agent for IBEW local 1.
The plate is actually a sticker a friend made for me. He did a great job, it evens reflex's light just like the real deal.
Just a way to help me connect with my Brothers and Sisters at the track and I guess now I can say the forum too.
Old 09-16-2017, 08:03 PM   #125
Car: 1983 Camaro Z28
Engine: 383
Transmission: TH-350 w/ transbrake
Axle/Gears: 4.11 Moser 9 inch Detroit Locker
Trying to get out one more time. Ended up changing from a th350 to a glide. Waiting on the converter and trans to show up. Still gunnning for that 8 sec pass. I haven't been able to turn up the car at all yet. Soon enough though.
izcain is offline   Reply With Quote
Old 09-18-2017, 08:07 AM   #126
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Quote:
Originally Posted by 3rdgenmaro View Post
Different type of racing then you of course, but my main goal is to not total the car. Be competitive and get another win.
Well, I didn't quite meet my goal, but came close. Had more competition this year. Couple 2nd places, a couple 3rd places, and a heat race win. Car has a lot more dents, but she is still rolling.
3rdgenmaro is offline   Reply With Quote
Go Back   Third Generation F-Body Message Boards >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
Vendor Directory
1982 Camaro '82 || 1983 Camaro '83 || 1984 Camaro '84 || 1985 Camaro '85 || 1986 Camaro '86 || 1987 Camaro '87 || 1988 Camaro '88 || 1989 Camaro '89 || 1990 Camaro '90 || 1991 Camaro '91 || 1992 Camaro '92
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
