V6 springs in bracket car
I've seen where people have used the v6 springs in the front but when I look them up it seems there's a bunch to choose from. I want to know which one's people have used (part number)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: V6 springs in bracket car
I ran V6 springs for a few years when my car was still basically stock. I just went to the junkyard and pulled a set from a car. I use Moroso Trick springs now.
Springs hold the weight of the car up at ride height. The shocks do all the work. Too light a spring and the weight of the car compresses them too much and you don't want them compressed enough to get coil bind when the front end bottoms out. Too stiff a spring and the weight of the car barely compresses them and the shocks do very little work.
I've got a spring sagging and wanted to put springs in to get me by til I get money to get the moroso ones or if the ones I get work then I'd just leave it alone
i used v6 springs in a car that had a 388 ci sbc on pump gas ran 7.24 to the 1/8 and at 98 mph. car actually left with fronts slightly in air.
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I had a V6 and swapped a 385 in it the other day. Still have the V6 springs. I didnt notice much of a difference but it does seem to sit lower. But on a launch it feels the same. I have lakewood 90/10 struts and 70/30 shocks without a roll bar in the front. It comes up and stays that way when launching. Even before the V8 swap.
I have Global West #4256 Street/Drag front springs.
But nobody seems to anything about them.
